Track Day Checklist
Track Day Checklist
Hi Folks,
On another thread I was asked what a new guy should bring to on his first track day. Don't know if this exists elsewhere on this site. I did not see it on my search. So here is the list I gave them.
Please add what is in your track day kit bag:
Before You Go to the Track
Bring to the Track
Be Ready to Learn
The final thing and most important I will add is bring an open mind. Things have very fast on a track. I am still shocked how much I learn each time and how little street driving or canyon runs does not translate great times on the track. Look at the transponder results, more often than not, the cars that beat you around the track are not the other GT3s and Ferraris. It is spec caymans, older 911s, 944s and sometimes Miatas . You will find that the best drivers don't have the fastest cars. The data does not lie and it will show you that it is the human, not the horsepower that matters.
- Print a map of the track to study before you go
- Search youtube for the track name to get a feel for the track
- Tech check you car (Brakes, Fluids, Tires etc.)
- Check on your insurance for HPDE exclusions or get track insurance
- Order some Vinyl numbers. magnetic ones would attach to the aluminum body. I got mine here (http://www.trackdecals.com/)
Bring to the Track
- Approved Helmet
- Gloves (I just bring gloves from Home Depot)
- Sunglasses
- Gopro(s) with internal and external mounts
- Long sleeve cotton shirt and jeans if you are not using a racesuit
- Driving shoes (cross trainers and running shoes can get in the way)
- Tool box with the basics (variety of screwdrivers, wire cutters, multiple pliers, leatherman, good knife, Duct tape, set of sockets, metrics)
- Extra set of brake pads
- Blue painters tape to cover headlights and other items you wish protect. (Some guys build a whole front end wrap out of the stuff
- Extra quarts of Oil and brake fluid
- Extra tire repair kit (Most of these tracks are out in the middle of no where)
- Tire Pressure gage (Most tracks have a compressor you can use)
- Full tank of gas. (Many tracks will sell gas and race gas, but the price can be high)
- Zip ties (for the transponder and wire cutters to get it off the car)
- I need build a center lock change kit (Some good videos here)
- Very fine edge screwdriver to pry open the tow hook port, (I knicked up my clear wrap not having the right tool)
- Tow Hook (but this is included in the tool kit in the frunk.)
- A book or Ipad, lots of waiting between sessions
- Protein bars and Lots of water
- Some 5 hour caffeine shots
- Folding Chair
- If possible have spouse of second drivers and car, just in case yours can not be driven home.
Be Ready to Learn
good list. I also bring a flashlight- useful to check brake pads, tires, under the car . Torque wrench, although first time you can usually borrow one. Also know your torque specs or bring the owners manual. CLs a whole other subject..... I'd say go easy on the caffeine and include some sport drinks like Gatorade. Hydration is very important even if the temps are not too hot. Hat and sunscreen. I'd also recommend something to take notes with- like tire pressures, class notes etc. Agree with leaving the ego at home. try to relax, listen to instructors and have fun!
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,781 Likes
Napping > caffeine
A tarp to put your stuff on the tarmac, I use a nice water resistant zipper bag that pretty much holds everything I don't need in the car. Check tire pressures when cold before you leave home. Go to the track with an open mind ready to learn...
Ok at the risk of getting flamed here I'll ask a question and no I haven't used the search function!! I've never taken a car on the track but am a pretty expericed track rider on bikes and you MUST drop the OEM suggested road pressures to track pressures or you'll have a big problem. For example if I could (legally) ride my track bike on the street I'd have 36 F and 42 psi in the rear. On the track I run 29F 28R. I had assumed you'd do the same with car tires. The above suggests you don't? Txs.
Good list.
One thing that I assume was included is a torque wrench. I always check the torque of my wheels after lunch, so it's after the second session and the car has cooled a bit.
Yes, you do that.
Unfortunately, I've met too many Porsche driver's who have had really enormous egos about their driving skills, but couldn't back it up on the track. While I'm not one to criticize anyone's skill, egos are the worst thing to have at track days. Not only does it annoy others, but it also puts you and others at risk if you're driving way over your abilities or have something to prove.
My point on tire pressure was to have a close starting point when cold as a reference, i.e. 29/33. I adjust pressures as the day goes on and track and OAT change. You still need a starting point.
Michelin provides guidance on the tire pressure for the MPSC2:
http://www.michelin.co.uk/tyres/mich...ot-sport-cup-2
