First Oil Change
Porsche filter is $50. Didn't have a chance to look at mobile 1 prices so just picked it up at local car parts store. Not sure I would get an off brand oil filter.
http://www.paragon-products.com/prod...107.203.90.htm
Still crazy for an oil filter.
I tried to get tubing down far enough to vacuum out but couldn't get any oil out. How much tubing did you stick in there, and how did you get around the snags?
Drove 25 miles each way for the oil change this AM. Tech Put's the car on the lift and decides to make sure they have the oil filter on hand before he does anything and guess what? uurrrrr No oil filter in stock
GM comes up and tells me I am invited for a privet track day June 19th at Laguna Seca so the day was not totally wasted.
If you are going in for an oil change, call parts to make sure they have your oil filter available and save yourself a trip. I have never had such a case.
Order a couple of filters and seals. When I had my oil changed I took the filter with me. It might have helped that I purchased it from the dealer's parts department.
Yep, that was my plan when I go back next Saturday. I will stock up couple filters. Oil is available everywhere.
New data point. Received yellow warning oil at minimum level. Current odo 7500 miles, as thread indicated, oil change took place after break-in. One track day took place thereafter.
Filled approximately 100ml. Yellow is gone, I'll check it out again tomorrow to see if it's still off or if that little addition gives me the dreaded overfill.
Still seem to have plenty of tread left on MPSC2s and I'm pleased with that!
Dan (logs)
Dan (logs)
So far no problem with the small addition of oil. Surprised just a 100 ml or about 1/10 of a quart made the difference between an idiot light and smooth sailing.
I changed the oil today at 1000 mi. The oil was up to 195F when the car was put on the lift. Drained for a little over a half hour. The manual lists 7.5 liters with a filter and I put in 7 liters of Motul 5W40 and connected the PIWIS. It read .1 liter over filled. I was able to get a 1/4" diameter piece of tygon tubing through the fill opening and vacuum out about 3 ounces. After that the car indicated plus 2 green bars.. Next change I'll subtract 3 oz/300 ml before filling.
I collected a sample for oil analysis. I'll post the results when I get them.
Just had my 1st change at 1800mi - was going to do it myself but ended up needing the thermostat replaced so figured what the heck. Dealer charged $189, not bad! I had them save me a sample so I could send off for analysis
