991 GT3, GT3RS, GT2RS and 911R 2012-2019
LIFT
Old 01-09-2015, 10:02 PM
silverrules
silverrules's Avatar
Default LIFT
Folks
Instead of buying all the ramps and the jacks, wouldn't it be more cost effective to go with a lift? This way you don't need to crawl under the car for oil change etc.
Wonder if anyone has a cost effective lift solution for their garage thats less than $2K or close to that. If yes, price, model, spec please.
Thx in advance
Old 01-09-2015, 10:10 PM
Jpacione
Jpacione's Avatar
Originally Posted by silverrules
Folks
Thx in advance
Funny, I have been thinking the same way. Glad you asked the question!
Old 01-09-2015, 10:12 PM
orthojoe
orthojoe's Avatar
Lifts are surprisingly inexpensive, so it's a good option if you have the space
Old 01-09-2015, 10:20 PM
JFA65
JFA65's Avatar
Caution. Poor quality made in China lifts are throughout the market place. Most clearly state " Made in USA". Most are sold by USA companies. Do you want to be under a lift with a well documented failure rate. They are immune from our tort system. Buy carefully and be aware you sometimes get what you pay for.
Old 01-09-2015, 10:41 PM
zedcat
zedcat's Avatar
I'm happy with my Bendpak xpr10A. Was about $3k. But- needs 145 in ceiling clearance. Seems there was an earlier thread on lifts- 2 post vs. 4 post . Can't recall for sure.
Old 01-09-2015, 10:45 PM
reidry
reidry's Avatar
Folks
Thx in advance
We'll need to know more about your garage space and type of lift you need before we can make a recommendation.
What is our ceiling height?
What type of overhead door do you have?
Does the overhead door reduce the effective clearance height in the location you intend to install the lift?
What type of lift do you need?
- A semi-permanent/permanent storage or parking lift that effectively doubles your parking space.
- A permanent full rise service lift - typically two post type.
- A permanent mid-rise service lift - typically scissor type.
- A temporary service lift.
If you're unsure of the type you want, please let us know the intended uses (e.g. storage, fluids service, wheel tire service).
On price - are you looking 2k installed or do you have the skills to install a lift yourself?
Absolutely concur! You want an ALI / ELI certified lift. Safety is paramount.
Ryan
Old 01-09-2015, 10:49 PM
Just in time
Just in time's Avatar
Look for an ALI certified lift. Most lifts are now made in China. Some are built by subcontractors others are built by USA companies that have their own manufacturing in China. Look for BendPak or Direct lift. As the previous poster correctly points out there are a number of items u have to look at before deciding.
Old 01-09-2015, 11:27 PM
silverrules
Thanks for your feedbacks.
Ryan,
Hope this answers the questions you asked
What is our ceiling height? Ceiling H=147" and it seems the car can be lifted and clear the rails when the garage door is closed
What type of overhead door do you have? Not sure. Please see pic posted.
Does the overhead door reduce the effective clearance height in the location you intend to install the lift?[B]Yes it does. Measuring from the rail to floor H=125"
What type of lift do you need? Would be nice to store one car on top and service the GT3 in other times
- A permanent full rise service lift - typically two post type. Permanent lift would be nice. I plan to stay in this house until buried.
Old 01-09-2015, 11:42 PM
Just in time
I would look for a four past lift given that u want to park a car on it.
Old 01-09-2015, 11:44 PM
orthojoe
orthojoe's Avatar
You've got plenty of ceiling height. You want to add up the height of 2 cars (typically 50" for sports cars) plus 8. So minimum of 108". I have 116", and it's about as close as I would want to be to stack 2 cars.
Old 01-09-2015, 11:48 PM
silverrules
4 post makes more sense guys.
Found this link by Jimmy.
https://rennlist.com/forums/991-gt3/...-garage-2.html
Old 01-09-2015, 11:53 PM
silverrules
Thx Joe. It should work. Not sure why zedcat lift needs 145"?
Old 01-09-2015, 11:55 PM
orthojoe
orthojoe's Avatar
The only criticism I have of the 4 post is that maintenance that requires the wheels lifted up is a pain in the ***. The rolling jacks that run underneath to lift the car up off the lift itself take forever to jack up. For doing quick wheel and brake pad swaps I find myself just using a regular floor jack rather than bother with the tedious process of using the lift.
a 2 post is much better for maintenance, but you can't stack cars.
Old 01-09-2015, 11:56 PM
orthojoe
orthojoe's Avatar
Not sure. My lift is from Greg smith equipment
Here is a pic of my stacked setup
Old 01-10-2015, 12:33 AM
silverrules
That's one clean garage. Time for me to clean up Makes sense about the wheel maintenance but nice to stack them up like you have. Oil change will be quick!!
Thanks again
Quick Reply: LIFT
