Gentlemen I really need your help
#31
Nick, maybe we're dealing with semantics here but can you clarify your assertion with respect to the extract from the Porsche technical docs below? Based on the info it would seem that there is an active component to the pressure regulation and not just the passive effect of the bearing clearances.
1.10 Oil supply
Compared with the current 911 Carrera models, the new 911 GT3 features classic
dry-sump lubrication with a separate engine oil tank. This system ensures a reliable
oil supply for street and race circuit use.
Red - Pressure side
Orange - Intake side
Dry-sump lubrication
To allow dry-sump lubrication based on the new generation of engines (991), the oil
pan had to be completely redeveloped. The basis for this is the oil supply system
used in the current 911 Carrera models with four oil extraction pumps for the cylinder
heads, an additional oil extraction pump in the oil pan and an oil pressure pump.
There are also two additional oil extraction points in the oil pan at the front and rear
so that the oil can be pumped out reliably into the separate oil tank even during
heavy acceleration and intensive braking phases.
Oil pump
In order to reduce the drive losses of auxiliary units as well as churning losses, the
new 911 GT3 is equipped with an electronic demand-controlled oil pump. With this
oil pump, the delivery pressure and volume are controlled for the entire engine map.
It also ensures demand-controlled lubrication and minimizes the energy consumption
of the oil pump.
1 - Variable pressure pump
2 - Suction pump (4 x)
3 - Control valve
In addition to the demand-controlled oil pump, the new 911 GT3 is fitted with not
just one (911 Carrera) but two piston oil spray nozzles, which are opened together,
depending on the temperature, load and engine speed. This allows more intensive
cooling of the pistons, which are subjected to high thermal loads.
1.10 Oil supply
Red - Pressure side
Oil pump
of the oil pump.
3 - Control valve
#32
Gravity, IIRC when I posted my numbers to your other thread I noted 70 PSI @ 7K rpm and 72 PSI @ 8K rpm. So yeah, I hit 5 bar (72 PSI) at high rpm.
#33
Same here. And Gravity don't worry, people do not think you are too sensitive. You should watch out for your car...but I remember when I had gtr when it first came out, the so called gtr master did not know jack about the car. So I started to look into a lot of things myself, and I did scare myself a few times which turned out to be nothing. (Hey I was not talking the transmission grinding noise which I knew was normal) so I hope given gt3 is brand new design that these phenomenon may be a normal variation. Relax, enjoy the car as much as you should, if it happens again, then have them repaired it. And screw it get a .2 when it comes out.
#34
That's great, Gravity. I know there were concerns at one time as to how Porsche was treating some of it's most loyal and enthusiastic customers (ie GT car buyers), but I don't think there is any doubt now that they have and will continue to bend over backwards to make sure things are right with this car. Glad you are happy with the resolution of your issue.
#35
IF you are concerned with these number, I am pretty sure they are normal numbers. The demand for oil lubrication is high at high rpm and you should expect the oil pressures to be high to keep up with the demand. Please let me know if you want us to run more numbers for you. Mark
#36
Again thanks for all your help guys still waiting on Porsche. I'm still pegging 5 bar at 5000 tho but that's why it's got 6 years warranty. I bought the extra 2 I keep all my cars
