991 GT3, GT3RS, GT2RS and 911R 2012-2019
Brake screech
Old 01-04-2015, 08:31 PM
dadams1598
dadams1598's Avatar
Default Brake screech
I went for a nice ride today and am up to 270 miles now. Car is feeling better each time I take it out and sure wants to rev. My breaks are still screeching very loud when breaking for a light or stop sign. For those of you with more miles when does this go away? Very annoying and embarrassing when pulling up next to someone.
Car is flat out amazing and the most invigorating car I have ever owned.
Old 01-04-2015, 08:33 PM
sdg1871
sdg1871's Avatar
Do you have the PCCB?
Old 01-04-2015, 08:34 PM
dadams1598
dadams1598's Avatar
Sorry meant to note I have the steel brakes.
Old 01-04-2015, 08:38 PM
hfm
hfm's Avatar
BEDDING IN BRAKES
Step 1 Find a long stretch of unpopulated road.
Step 2 Go from 70 to 0 hard but not so hard that ABS kicks in.
Step 3 Rinse and repeat 10 times.
Step 4 Enjoy your squeal free brakes.
Dan (says it doesn't matter if they're steel or PCCB)
Old 01-04-2015, 08:45 PM
dadams1598
dadams1598's Avatar
Thanks I guess it's time to taker her out again and "bed" her!
Old 01-04-2015, 08:54 PM
Just in time
Just in time's Avatar
I did some harder (not hard) braking and screeching went away. I only have 270 miles.
Old 01-04-2015, 09:05 PM
WernerE
WernerE's Avatar
Iron brakes, not steel.
My PCCB's on a TTS have never squealed, so I'm hopeful I'll not have any on my incoming GT3 w/PCCB's.
Old 01-04-2015, 09:12 PM
SamFromTX
SamFromTX's Avatar
Originally Posted by hfm
BEDDING IN BRAKES
Dan,
I think the pads and rotors need to get up to temp gradually before the actual bedding and what I once found on a Pagid insert (can't find again) goes like this:
Speed up to 70 or 80 then medium braking down to 40, wait 10 seconds or so then repeat for 10 times. This brings them to temp gradually. Then drive to 90-100 and brake hard (short of ABS) down to 40, twice. That's what I do but not sure it's better than what you said.
Sam (is pretty sure the squeal will come back because the GT3 pad has a more track oriented composition).
Old 01-04-2015, 09:35 PM
hfm
hfm's Avatar
Originally Posted by SamFromTX
Dan,
Actually, I think you're right about bringing the temp up gradually from what I remember. As to the speeds, I'm don't think the precise speeds matter as much as the act of braking with sufficient force to set the pads into the rotors, hopefully removing any brake dust and making an impression that results in smooth contact between pads and rotors.
The squeal may come back, and you may have to repeat the bedding process. Other than that, I think the method you suggest is just fine, if not better. Me, I'll stick to simple since it's worked for me for years.
Old 01-04-2015, 09:38 PM
SamFromTX
SamFromTX's Avatar
Old 01-04-2015, 09:48 PM
Alan C.
Alan C.'s Avatar
At 1000 mi. I still get squealing. A couple of hard stops from 70 and it goes away for a time. Driving around town tends to shorten the interval. On a high note the brakes are excellent.
Old 01-04-2015, 10:16 PM
zedcat
zedcat's Avatar
I have 3000mi on iron rotors and they squeal. A mini bed-in seems to help but the squeal comes back. Doesn't bother me. It's not as bad as the Pagids on my Cayman.
Old 01-04-2015, 11:24 PM
spooky
spooky's Avatar
Some good information can be found here http://www.stoptech.com/technical-su...l-white-papers on bed-in and other braking topics. Personally I'd not go down to 0mph on the brakes when bedding in, or hot brakes, unless there was a necessity.
Old 01-04-2015, 11:46 PM
kyrocks
kyrocks's Avatar
GT3 brakes will squeal.
Old 01-04-2015, 11:50 PM
seapar
seapar's Avatar
I find that whether ceramics or steel/iron that squeal is most pronounced with the cold and with easing gently on the brakes around town. More abrupt application (not so much you bother the person behind you) seems IMO to help. Try it and report back to us. Medium bedding 70-35 mph could also help at operating temps.
Quick Reply: Brake screech
