Plastidipped my washer nipples
I picked up a can of plastidip earlier and popped off my washer nipples to give them a coat.
The plastidip goes on pretty easily. I'm not really stoked on how it looks though, and i'll probably have them painted. The caps come off pretty easily once you get the washer up.
If you take a small screwdriver into the under side of the cover you can lift the washer up, it will come up about 5". Once its up there are a couple of tabs that keep the cover on, I tried to push the tabs in a little while wiggling it around until it breaks loose. To put it back on your just line it up and push down.
If you wait between coats of plastidip, and apply evenly, It won't look like that. you can make it look perfectly smooth, that's just your first attempt. Peel It off and try again, you'll get better at it and it can look like paint
Thanks for the tip! I'll practice on something else before I pop these off and try again. My first attempt I went too thick and I had a lot of bubbles coming through, maybe I was just applying layers too quickly.
Yup.. First layer very thin.. Wait for 20 min or so. Repeat until 3 coats but each one thin. Should work for you. Have fun with it
