991 GT3, GT3RS, GT2RS and 911R 2012-2019
should I break in? Picking her up in few hours
Old 11-28-2014, 02:27 PM
  #31
ipse dixit
ipse dixit's Avatar
Received 12,102 Likes on 5,262 Posts
Originally Posted by Mike in CA
Let's not be too literal, guys. The point of my example wasn't about having a story to tell the next buyer or to suggest that one would realistically find 2 cars exactly alike. But if the OP knows which car he would prefer in the hypothetical situation, then he knows whether he should do a traditional break-in or not with his own car, which was his question. Simple as that.
Hey Mike, hope you know I was only joking.
Engine break-in is one of those personal things. Like the FAL.
Old 11-28-2014, 02:52 PM
  #32
Mike in CA
Mike in CA's Avatar
Originally Posted by hfm
Well crap, I just read this and am re-evaluating.
http://yel.pca.org/porsche-engine-break-in/
Dan (is annoyed when indecisive)
And that's why we hash this stuff out over and over....I learn something on this forum almost every day.
As 911dev points out, there is not a definitive body of information on this issue. To the best of my knowledge, nobody on the outside has ever done a controlled scientific study on a large batch of engines, over many years, to determine rates of wear at various times in engines that were broken in different ways. The people with the best insight into this issue are the manufacturers and we know and some distrust what THEY say. Anything else we hear anecdotally on forums, from individual techs, owners, or your local engine builder is unscientific speculation.
Which is why it comes down to an emotional decision and we have these repeated discussions in an attempt to validate our choices.
Mike (who must add, that article was pretty enlightening and validates HIS choice....)
ipse, it must have been my turkey overload....I wasn't sure if you were joking. My bad. And I agree completely; the decision on engine break-in is definitely personal.
Old 11-28-2014, 02:57 PM
  #33
rockitman
rockitman's Avatar
Makes sense to me. I am going to take it easy varying revs for the first 1000 with some short bursts up 7,000 after 500 miles. I will drive in manual to always keep revs above 2k...so as to avoid any bogging.
Old 11-28-2014, 03:14 PM
  #34
Mike in CA
Mike in CA's Avatar
Originally Posted by 911dev
Great read, thanks!
The article is dated 2011. I do not believe they dyno every engine anymore, although I could be mistaken. Regardless, the basic fundamentals are there.
Mike in Cali will appreciate the four paragraph from the bottom.
I did notice that, Chris!
I believe each car, as it comes off the production line, is run on the rolling dyno and each engine is cold/dry-run on a test jig, but generally only a very small percentage of engines are now hot-run up to 80% on the engine dyno for 30 minutes.
Except for our GT3 engines. When I was at the factory this past June I was told that, as an additional quality check after the connecting rod problem, every GT3 replacement engine was being hot-run dyno tested.
Old 11-28-2014, 03:51 PM
  #35
911dev
911dev's Avatar
Good to know.
Old 11-28-2014, 04:04 PM
  #36
WernerE
WernerE's Avatar
I've always kept things under 4,500 - 5,000 RPM before 1,500 -1,800 miles. It's not easy, but the article linked to by Mike CA appears more credible than the glib "drive it like you stole it" suggestion.
Old 11-28-2014, 04:50 PM
  #37
aamersa
aamersa's Avatar
I drive my cars hard from the beginning. I don't abuse them but never really worry about where the needle is on the rpm. No problems encountered so far. Also I tend to put on lots of mileage in the first 6-12 months in the process catching any potential problems that need attention of the warranty. I never change engine oil except per manufacturer schedule. To each their own. Some get just as much pleasure babying their cars as others get driving them. Either way it is still pleasure, the main reason we buy these cars. My gt3 is due in port Dec 22.
Old 11-28-2014, 05:29 PM
  #38
devenh
devenh's Avatar
The article seems to stress controlling heat as opposed to RPM. Running sustained high RPM's obviously builds heat, so this should be avoided. But it doesn't seem to rule out short bursts of high RPM's that wouldn't move the engine temperature needle much.
Old 11-28-2014, 06:26 PM
  #39
Napoli
Napoli's Avatar
This. But, why, then (again), only for USA owners?
Old 11-28-2014, 06:30 PM
  #40
Mike in CA
Mike in CA's Avatar
The article refers to heat being generated by driving the engine for an "extended period of time", not just driving at sustained high RPM, which isn't typical for street driving anyway. I think all of us have experienced engine temperatures climbing in everyday driving on a warm day in traffic, where sustained high RPM isn't even a remote possibility.
Oil and water temperature gauges may give an accurate measure of fluid temperatures, but aren't necessarily the best indicator of the thermal stress on individual components, so I don't know how anyone could determine when engine parts were not too cold, not to hot, but just right to sneak in a quick high RPM burst.
If one believes the info in the article, the logic of why a measured break-in is a good idea is pretty clear. If one doesn't believe it, then carry on. But regardless of the facts, we all often find ways to rationalize how our own preconceptions are correct, don't we.....
Old 11-28-2014, 06:45 PM
  #41
Mike in CA
Mike in CA's Avatar
This continues to be repeated. Does it really say nothing about break-in in ROW owner's manuals?
Old 11-28-2014, 06:53 PM
  #42
rockitman
rockitman's Avatar
I think your procedure has been validated versus multiple launch control starts through the gears for first 30 - 200 miles on a repeated basis.
Old 11-28-2014, 07:37 PM
  #43
R.Deacon
R.Deacon's Avatar
Dan,
Well crap is right, I was thinking 1000 miles oil change then Sebring,
guess next weekend I drive to my Doctor in NYC and back to FL
varying the throttle the whole way of coarse.
My last car 997.2 Targa 4s I left the dealer and the next day drove it to R.I. from Fl.
that motor was built proof for me in 60+ track events
Deacon
Old 11-28-2014, 07:55 PM
  #44
Lodi
Lodi's Avatar
Good read Dan. Thanks! I wonder if the use of synthetic oil makes the break in process longer. I have a tiny amount of experience building motorcycle engines. I never used synthetic till after an engine was broken in. The logic was that you wanted the additional friction of non-synthetic oil improve the seating process.
Old 11-28-2014, 08:39 PM
  #45
hfm
hfm's Avatar
Originally Posted by R.Deacon
Dan,
Deacon
Deacon,
Sorry to spoil your Sebring trip. If it's any consolation, I'm going with Herr Porsche Engineeer's recommendation too and won't be redlining until 2k. I will break in per factory recommendations varying throttle as well, doing longer trips, warming up before moving and keeping under 4,200.
Lodi,
I agree, synthetic makes break in longer. Some people might use regular oil but, I don't think I'm going to do that nor do I think I will do the oil change at 50 miles or 1-2k miles. I think I'm just going to go with whatever Porsche guidelines are at this point and hope I don't end up with an oil consuming engine. If I do, it will be covered.
Dan (doesn't fight expert opinion)
Quick Reply: should I break in? Picking her up in few hours
