991 GT3, GT3RS, GT2RS and 911R 2012-2019
991 GT3 overspeed events
Old 10-01-2014, 11:52 PM
  #61
996FLT6
996FLT6's Avatar
Let's say u in manual mode and coasting to a stop in 3rd gear. Does it stay in 3rd or defaults to 1st. Mike
Old 10-01-2014, 11:57 PM
  #62
doubleurx
doubleurx's Avatar
It changes to first.
Old 10-02-2014, 12:55 AM
  #63
996FLT6
996FLT6's Avatar
So it does default to 1st gear on a stop? Always thought it stayed in gear in
manual mode. This is for PDK-s rt? Mike
Old 10-02-2014, 12:59 AM
  #64
doubleurx
doubleurx's Avatar
So it does default to 1st gear on a stop? Always thought it stayed in gear in manual mode. This is for PDK-s rt? Mike
Yes, and yes, but why would you want it to be in 3rd at a stop? Other than that, it stays in the gear you choose.
Old 10-02-2014, 01:08 AM
  #65
996FLT6
996FLT6's Avatar
People say it stays in gear if chosen just want to correct that's not the case. It's still in auto default mode. It's truly not manual mode. Mike
Old 10-02-2014, 01:13 AM
  #66
doubleurx
doubleurx's Avatar
If it didn't drop into first it would stall. It only does this when you are at a stop. Otherwise it stays in the gear you choose. It will bounce off the rev limiter. It also does not creep in first or reverse, so you have to be prepared as it can roll.
I'm not sure what you are getting at. With a manual do you leave it in third at a stop? I don't.
Old 10-02-2014, 01:25 AM
  #67
996FLT6
996FLT6's Avatar
I use 3rd gear to check if my clutch is failing on a stop. If it stalls time to change. Mike
Old 10-02-2014, 01:27 AM
  #68
996FLT6
996FLT6's Avatar
How do u know if PDK starts to fail? Mike
Old 10-02-2014, 01:29 AM
  #69
doubleurx
doubleurx's Avatar
How often do you do this? I think I know why your clutches may have failed on the past.....LOL!
Old 10-02-2014, 01:36 AM
  #70
996FLT6
996FLT6's Avatar
^whatever you are thinking about y my clutch fails its probably true- lol. Anyway- PDK is not bullet proof it will wear over time question how do u know ie early symptoms? Mike
Old 10-02-2014, 01:43 AM
  #71
doubleurx
doubleurx's Avatar
I haven't heard of any failures so who knows. It will probably give you a code, slippage, loud noises?... Since Porsche has done some extensive testing with consecutive launch control runs, I think it is pretty bomber. I can't remember the number of times, but it was far more than a normal clutch could take.
Old 10-02-2014, 03:02 AM
  #72
Mike in CA
Mike in CA's Avatar
Originally Posted by Manifold
So if you pull the paddles to put it in neutral, and coast in neutral for a while, will the PDK simply select a reasonable gear when you let the paddles go?
Yes, in the auto modes for sure. In manual mode it will probably still be in the gear you were in when you pulled the paddles until you are slowing nearly to a stop when it would downshift. I haven't actually tried this in paddle neutral so I'm not 100% sure. You guys are going to have lots of fun trying out some of the less common scenarios when you get your cars!
Nick (doubleurx) is right; there are a number of fault codes that the transmission will throw in the dash display to warn of gearbox problems or failure. FWIW, the clutches in the PDK box are supposed to be lifetime items.
Old 10-02-2014, 03:13 AM
  #73
TRAKCAR
TRAKCAR's Avatar
Received 1,585 Likes on 733 Posts
Lifetime. Right, like gearbox oil but once tracked needs at least replaced every 12 days..
How do you replace gear oil in the 991?
Old 10-02-2014, 03:14 AM
  #74
mooty
GT3 player par excellence
mooty's Avatar
Received 5,480 Likes on 2,269 Posts
1st
Old 10-02-2014, 03:19 AM
  #75
mooty
mooty's Avatar
LIFETIME. you know better, mike!
all of 96flt6's toys fail. he has mad sKiLlz
Quick Reply: 991 GT3 overspeed events
