Launch control
#32
Umm the Turbo S has 560 hp and 553 torque and the standard PDK and you guys are worried about your measly 475 hp and 325 tq. and welcome to the PDK-S. !! You own a race car. Go try to break it before your warranty wears out.
I wanna walk into a bar and yell at the top of my lungs " Launch Control on the house!"
Don't be afraid of your cars boys. Go drive them!
#33
Seems like I should know the answer to that. Kamal, did you read somewhere that was the case? Because of the aggressive mapping in PDK sport mode I bet you'd need some pretty serious speed to see 7th gear but since top speed is achieved in 7th I don't think it would be locked out. If you've got a good place on HWY 49 maybe you should test the theory.
#34
Note: it mentions sport to the left of the speed indication and the transmission is left in "D"
#36
So DME (over-rev) reports on these cars will be meaningless, I assume? Both a car driven under 8k rpms at all times and one with 1000 launch controls would show zero over-revs, correct?
#37
Mike, I will after its broken in and with the Sharkwerk exhaust installed and will share the video. It's a straight shot with hardly any cars around most of the time. One of the sales guys who is truly a car fan told me about the 6 gears limit but this video that was just posted proves him wrong I guess unless if I am missing something.
#40
Anybody know if that video was stock 991 GT3?
I must be missing something but I thought the speedo got to 334 kph (207 mph). Is top speed really that much more than Porsche published specs?
#42
Speedometers are notoriously unreliable at high speed. GPS measured speedos are commonly used for top speed tests. I wouldn't dwell on the thought that the GT3 is topping over 200 mph, it probably wasn't.
#43
Dan (knows adding exhaust modifications to a NA engine doesn't give much HP increase)
#44
I suspect your sales guy might be confusing this feature of PDK with PDK-S, where 7th is required for top speed. There's no mention of a 7th gear lockout in the GT3 manual. Obviously 7th gear can be engaged in auto mode per Zulu Alpha's video and I bet it can be selected in manual/ PDK sport mode too. Shouldn't need super high speed to try that out.....
