Red viper has arrived
Great stuff Drifting. Good to have you in the camp finally.
The PSE in my opinion is not cut and dry - in that it cuts in when the button is on at different places on the rev band dependant on engine temp, load, throttle position etc. I believe its part of teh ECU programming and was done for noise emissions in Europe. Mine seems in consistent. Try turning it on at constant speed around 4000 rpm+ with partial throttle and you should hear the sound deepen - if not worth having checked out as may be a sticky valve. Im sure it was more consistent with the old engine so I suspect it has something to do with the new software but I will try it unplugged soon and see if I prefer that...
Congratulations! Awesome color.
The black lights suit the color perfectly.
Yep 500 for me , and let her rip! My buddy did 100 and, and called it day with a Porsche hot lap on a test track.
Drifting, its your crap roads it will be caddy-like in South Florida, even the RS I bet.
The rear view being blocked is annoying but I don't see how it can be fixed like on the 997RS (and 991RS?) with taller uprights, 4" taller made all the difference like we see all the time on the Riviera blue and orange Sharky 4.1L car.
Congratulations on the car.
Can u be selective on your backgrounds? So far frayed's and yours has a fire extinguisher in the background!!!! Anyway love the black out headlites. Mike
Yeah, get red. I need more red cars to dilute the sea of whites...
Drifting, it looks awesome. Massive congrats!
The PSE can be a little subtle in terms of when it activates. To test whether it's working start the car in the garage after it's warm and listen with the windows down at idle. Press the PSE button and you should be able to hear the exhaust note change to a deeper fuller bass sound when the valves open.
Also, with the exhaust cool of course, reach around behind the valve on each side of the center muffler and feel for the flapper valve control rod. You should be able to freely move the rod up against the spring pressure with your hand. This will help you determine if a valve is stuck or not.
The flaps open and close as you describe. Iircc, this is intended to increase torque.
