GT3 Rear Steering Demonstration
Former Vendor
In a post from last week, user 'skuplist' uploaded a video (link) of the rear axle steering action on a 991 Turbo. We've shot a comparison video using our GT3 and documented the actual mechanism in action.
The mechanism behind the rear steering action is an actuator that replaces the Track Rod (pictured below). Track rod is responsible for the toe alignment. Replacing the track rod with an actuator changes the toe dynamically.
for more angles of the rear suspension, please reference our suspension navigator (link)
The video is shot at idle. At this speed the movement is greatest and most visible. The rear wheel counter steer up to 50 miles per hour to create an effective wheelbase that is shorter, and making the car more maneuverable. Above 50 mph the wheel steer in the same direction for improved stability.
Enjoy.
Enjoy.
Enjoy.
Enjoy.
Former Vendor
I am curious how does this changes the whole camber of the tires? what about under load? and how robust it is? Also, what sort of maintenance is required to make sure this works fine in the long run?
That's a fantastic video demonstration of how the system works. Far greater movement than I expected to be honest. Thanx!
Just FYI, when the wheels were put back on, that rear CL locking pin wasn't fully engaged... It was only half way out.
...The video is shot at idle. At this speed the movement is greatest and most visible. The rear wheel counter steer up to 50 miles per hour to create an effective wheelbase that is shorter, and making the car more maneuverable. Above 50 mph the wheel steer in the same direction for improved stability.
Enjoy.
Enjoy.
