WWYD: accept the engine swapped GT3 or pass?
#61
The Cup car is a spec class just like 458 Challenge class. They can run whatever they want. The 458 runs the same DCT trans used in the street car save a shorter gear set.
GT3 America, GT3 R, and GT3 RSR are a different story but the base engine could certainly be used in all these applications just like the Mezger is in the current cars.
#62
The chances Porsche will use the 991GT3 engine in future racing is slim at this time,to say the least. The chances Porsche will learn from their mistakes at the customers expense and then make a durable DFI racing engine is what I envision for the future.
#63
Received 1,139 Likes
Was looking at used F 458s and found this gem on info:
"In 2012, Ferrari recalled certain 2011 and 2012 cars because the engine can freeze suddenly and possibly cause a crash. The F136 engines have crankshafts that were machined incorrectly. The automaker learned of one such incident from a review car lent to critics. Owners can choose from having a new engine installed by their dealer, having the engine removed and the work done by Ferrari North America or having a new crankshaft and bearings installed at the dealership."
It appears more commonplace than I thought.
#64
#65
Pardon the sarcasm, thanks for the post Max....
#66
......and if I had one of those 458's on order I would have cancelled and waited till next year. Again, why take a very expensive car with a potentially defective engine? Just wait till next year. Porsche/Ferrari/Mercedes makes no difference. There is no shame or whatever else you are referring to. Just common sense really...great car with a problem. Take one after the problem is fixed.
#67
#68
458
As an owner of a 2011 458 and waiting on the news about my GT3, There were about 100 Ferrari 458's that Ferrari identified in about 2 weeks that had a bad crank shaft. They knew exactly which cars has the bad crank shaft and made engine swaps done at the dealer. I saw several at my dealer being done. Mine was not one of the bad crankshafts. This was a supplier problem. They fixed it.
If as some of you are saying Porsche may need to replace all engines because they don;t know which one has a bad part from a supplier. That would say they have no control of what part went into what engine by which supplier. Thus anytime there is a supplier issue they would replace ALL engines. Don't thinks so. It the result is a supplier issues, my guess, Porsche knows exactly which cars have a bad part. If it's an engine design issue, that I can see a 100% engine replacement.
When we get our calls, we will find out.
#69
Received 1,722 Likes
Admittedly, my view is biased by years of watching engines popped in and out of Cup cars like it's nothing. I can see where folks new to the Porsche brand and or stretching for their first GT3 could be easily freaked out.
#70
Whatever action will be taken, whether an engine replacement for all vehicles or some other partial repair, it will be wide ranging to insure that all the bases are covered and no customer is left with a potentially suspect engine.
As you say, let's see what happens.
#71
I think it largely depends on whether he was for or against the changes to the car behind closed doors... We only know his public stance which he'd be required to present regardless.
There will however likely be some engineers who will find it hard to get automotive work as a result of this...
#72
Basic Sponsor
And again, nobody is saying the replaced engine GT3's will be a bad car or have issues in the future. What is being said is that the PERCEPTION to the next owner will be that its worth LESS. It's been like that since the beginning of time with cars - all original cars sell for more money than ones that have had major components replaced. Period. and especially with limited production or specialty models.
Put it another way....forget this whole engine thing for a moment: Lets say you're brand new GT3 arrived at the dealership, and someone backed into it in the parking lot before you were able to take delivery...and it did $50,000 worth of damage. The dealer said they would fix it completely and you'd never be able to tell what happened, it would be perfect...
Would you still take delivery if they gave you the option of backing out???
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
#73
Race cars and street cars are completely different. There is no carfax, no insurance claims, none of that on a race car. Race cars are built for one purpose and one purpose alone - to win...and with race cars, it's EXPECTED to have engines and other components replaced and rebuilt due to wear and tear. That's EXPECTED. On a brand new street car, it should not be expected....
#74
I'm so glad you asked this question.
My head says ARE YOU STUPID]. I've been in business all my life. We design, manufacturer and distribute our own products. I've been through a recall. We had a problem but could not identify what the issue was. We had three independent mechanical engineering firms on it for months. Each one came up with a different root cause. All the cad programs, testing could not identify the real root cause. It ended up being a simple design fault. The only way it was identified was through extended testing which took months and months of observation. We then went about doing a complete recall. It cost millions of dollars but we did survive it and are a better company for it. My point is that an engine is a seriously complicated thing and that's a normal motor. this thing is cutting edge everything. There is a good chance Porsche may not have found the root cause of what ever the problem is. Or it may be a combination of a few things who knows. My business brain spends most of it's time assessing business risks. It's telling me to continue with this transaction is a big risk. Porsche may have the runs on the board for producing robust cars but when you push technology like they have even mighty Porsche might have bitten off a bit more than they can chew.
Now here's the thing. My Heart and soul says WHO THE f%**K CARES. anyone who is purchasing a GT3 for it's resale value is an absolute wan***r. The only and I mean the only reason to purchase this car is so that you can really enjoy yourself beating the crap out of it.
I have never driven this car so how hard is it to keep the faith. The only thing that keeps me in it are the comments from people about how truly great this car is.
So I guess I'll tick it and risk it. What's the worst thing that can happen. I might lose a significant amount of money. Well that's happened before and I am still breathing so I think I will follow my heart because I will not here forever and GOD this thing sounds exciting to drive. BETTER NOT TO DIE WONDERING.
#75
After considerable angst I decided to take the car even though it received an engine replacement. Checked with various knowledgeable people and the consensus was that as long as the installer knows what he is doing it should not be a problem.
To level the playing field for resale against cars which did not have their engines replaced, Porsche should extend the warranty on our cars.
