991 GT3 GT3RS and 911R
The 991GT3 Center Lock Procedure & "Auxiliary Tool"
Old 12-23-2013, 04:05 PM
Mike in CA
Mike in CA's Avatar
Originally Posted by CAlexio View Post
So as you need a platform due to the high torque forces, then is it impossible to change a flat tire on the side of the road using a regular jack?
Are you SOL if you get a flat tire in this car? Can you use some kind of tire filler gel to get to destination safely if not slowly?
You're pretty much SOL if you get a flat, and have been for quite a while with all Porsche sports cars, as there's no spare in the car to change to anyway. They give you a small compressor and tire goo. Or there's Porsche RSA.....
Mike in CA is offline
Old 12-23-2013, 04:11 PM
GrantG
GrantG's Avatar
I think you can do it, if you are traveling with a passenger who can apply the brake pedal with the engine running while you un-torque and torque the wheel (if you are traveling with a huge breaker bar or torque muliplier and a spare).
Otherwise the gel works on a small hole that is not in the sidewall.
GrantG is offline
Old 12-23-2013, 04:17 PM
CAlexio
Super User
CAlexio's Avatar
So basically, traveling alone through relatively desolate areas where a tow truck could take hrs to arrive (or longer) without a passenger is. Huge gamble in a Porsche with center locks?.
CAlexio is offline
Old 12-23-2013, 04:30 PM
GrantG
GrantG's Avatar
Yes, but as others have said, no new Porsche sports cars come with a spare tire (so you're not much more SOL than an owner of a 5-lug setup).
GrantG is offline
Old 12-23-2013, 05:01 PM
Dr.Bill
Dr.Bill's Avatar
Except that Discount Tire (or whatever non-Porsche tire place) will have no problem dealing with 5-lug wheels. Assuming they have the huge tires required. Not sure how many tire places will have a 4-foot long torque wrench, or a 4-foot long breaker bar, etc.
Just don't get a flat. Or use the car on a track. Or try to service the tires or brakes yourself. Or. . .
Dr.Bill is offline
Old 12-23-2013, 05:23 PM
CAlexio
Super User
CAlexio's Avatar
Oh boy... There goes my around the world in a gt3 blog idea.
CAlexio is offline
Old 12-23-2013, 05:55 PM
FLM911
User
FLM911's Avatar
Spare Wheels on the roof, a truck brake pedal depressor and your all set!!! Could be a good look, old school style.
FLM911 is offline
Old 12-23-2013, 06:36 PM
CAlexio
Super User
CAlexio's Avatar
Somebody please photoshop a gt3 into that LOL
CAlexio is offline
Old 12-24-2013, 01:11 AM
silverrules
Super User
silverrules's Avatar
I have worked with German engineers for many years. They crack me up. This is very typical. They make something that should be so simple this complicated.
silverrules is offline
Old 12-24-2013, 03:36 AM
mooty
GT3 player par excellence
mooty's Avatar
they do come with spares. that's why they made cayenne, aka support vehicle.
it carries tires, parts, blankets and junk food.
mooty is offline
Old 12-24-2013, 04:00 AM
Macca
Macca's Avatar
You just have to put it out of your mind or you would never have fun in these cars. I just completed 350km in the mountains and also 700km of back roads in Italy and would never have ventured around the villages in the hills if I kept thinking of the "maybes". You have to just take it by the scruff of the neck and shake it sometimes!
That said the possibility was always top of mind (and still is). A breaker bar can often be found with a truckie as they need then to torque wheel nuts. Getting a new MPSC2 tyre if ts too bad to repair would be my main concern....
Macca is offline
Old 12-24-2013, 05:31 AM
Peterfirst
Peterfirst's Avatar
NO offense against German engineers
I am one and I following Rennlist - as many other German (engineers) as well
Well I guess this is also better than taking short cuts ......
Peter
Peterfirst is offline
Old 12-24-2013, 07:53 AM
alpine-al
User
alpine-al's Avatar
I appreciate that you used extra emoticons just in case we misunderstood your intentions due to your German accent.
alpine-al is offline
Old 12-24-2013, 08:09 AM
911rox
911rox's Avatar
These German engineers are dumbarses... They suggest having a second set of bolts on hand for wheel changes yet all items have a km life... So are we suppose to keep logs on each individual component???... in reality, because different axles have different service lives, you can't even move bolts front to back, using additional bolts as many of us 997 guys did causes further issues, knowing when to time them out, etc, etc...
They've made life really difficult when tracking...
Some advice for those tracking:
- ensure your bolts remain on the same hub/axle from day one
- avoid running multiple sets of bolts concurrently unless you plan to keep a log on each bolt or risk losing track of when they need to be timed out...
ps. What is the timeout schedule for track use for the 991 per the manual for front/rear axles???
911rox is offline
Old 12-24-2013, 08:27 AM
Macca
Macca's Avatar
Chris from memory the replacent is 6000 track km one axle ana 12 the other. Its in the suplement called 1eacing with the handbook in my car in the valet at The Hermitage in Monte Carlo so it cannot check. Always wanted to say that all in the same sentence as it sounds so James Bond. ? Burger in this joint is 50usd lol! I think we will have dinner at the salvation army shelter maybe a four course with turkey1 We are only here for Xmas then off to St tropez to find some more driving roads...I will be putting flat tyres at the back of my ming again!
Macca is offline
Quick Reply: The 991GT3 Center Lock Procedure & "Auxiliary Tool"
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
