Car & Driver instrumented test of GT3
#46
This car was tested in Germany with likely the equivalent of US 95 octane in the tank....This would help to ensure every pony in the trunk was used to maximum effect. I would not be surprised to see Road and Track or Motor Trend post a slower time if they test a car in CA with our junk 91 swill in the tank.
#47
Thats a cop out argument. Thsi is comparative data. We are comparing it to figures for other recent Porsches and GT3 (aslo on R compound).
What about the ambient temperature, weight of driver, age of fuel/octane rating, altitude, condition of tarseal, time of day, humidity???????????????????????????????????????
Yes very had to find apples and apples. Lets not end up in another BS discussion about tyres vs tyres.
Its bloody quick. We know it, its been reported now in three separate independent tests. Discussion closed....
Whats of more interest is the relative power calcs. We knew it was around 490bhp as Andreas told us it was knocking on 500. Wonder how they will position the RS then....
For reference, here is a comparison of tires showing how much impact they can have on skidpad times:
http://www.caranddriver.com/features...-a-911-feature
#48
Absoutely correct. Europe uses RON (Research Octane Number), while the U.S. uses the formula (RON + MON) / 2, where MON is the Motor Octane Number. There is a 4 to 5 point differential between RON and the U. S. measurement.
#49
First, the acceleration numbers speak for themselves. No way to claim an unfair advantage there relative to other cars; the 991 GT3 is just damn fast and it's engine is clearly underrated at 475HP. As to skidpad and braking figures, other than guessing, there's no way to quantify how much of the improvement is due to tires and how much is due to improved brakes, chassis upgrades, RWS, etc.
Every time a new car comes out with the next generation of tires and other upgrades one could claim that's it's not fair to compare the new to the old. Whatever. The new package is what it is, and as a soon-to-be owner the fact that these numbers pretty much blow away all of my most optimistic expectations is all I really care about.
#50
The RS 4.0 trapped 122mph in R&T's testing with 494hp, and that is without the advantage of the latest generation tires, sophisticated launch computers, and lighting fast PDK shifts:
http://www.roadandtrack.com/cm/roada...S_4.0_data.pdf
#51
Thanks for posting the article. As for the Octane of gasoline, it is a common misconception that Europe has "better" gas. You do have a valid point about 91 Octane in California. Most of the other States have 93 Octane. Even then, it would most likely lower the trap speed by only 1 MPH to 125 MPH. That is damn fast.
For the street, as you suggest, losing a couple mph off my 1/4 mile trap speed is irrelevant.
#52
Wow - those interior sound levels seem extreme.
At full throttle, it's as loud as a gas mower, chain saw, or bulldozer! One hour of exposure to that sound pressure level can cause permanent hearing damage! And remember, noise damage is cumulative.
Cruising at 70mph is as loud as a washing machine, hair dryer, or garbage disposal. Sounds fun.
I guess they did away with the creature comforts!
It should be easy to tell who the new owners are. Ask them 'how is your new car?' and they will reply 'WHAT?'.
Let's hope their sound pressure meter is as poorly calibrated as their stopwatches are.
#53
You must be very excited Mike.
#54
A somewhat underrated motor seems likely given that trap speed. A 500 hp C6Z weighing about the same traps about that speed, so it makes sense. And yes, the tires do seem sticky given the launching for a RWD car and the braking power, either are only as good as the tires under them, especially with RWD.
Not hating, just stating the probability. Still fast either way.
Remove RWS and add Manual and I would do nasty things with a car capable of 126 mph traps. That's higher than my 600 hp TT trapped.
#55
But then again, Porsches only lose 7% through the drivetrain while many others are 10-15%. In any other car, it would be 500hp.
#56
http://www.pinux-products.com/octane-rating/
Generally, octane ratings are higher in Europe than they are in North America and most other parts of the world. This is especially true when comparing the lowest available octane level in each country. In many parts of Europe, 95 RON (90-91 AKI) is the minimum available standard, with 97/98 being higher specification (being called Super Unleaded). In Germany, big suppliers like Shell or Aral offer 100 octane gasoline (Shell V-Power, Aral Ultimate) at almost every gas station. In Australia, “regular” unleaded fuel is RON 91, “premium” unleaded with RON 95 is widely available, and RON 98 fuel is also reasonably common. Shell sells RON 100 petrol from a small number of service stations, most of which are located in capital cities. In Malaysia, the “regular” unleaded fuel is RON92, “premium” fuel is rated at RON97 and Shell’s V-Power at RON99. In other countries “regular” unleaded gasoline, when available, is sometimes as low as 85 RON (still with the more regular fuel - 95 - and premium around 98 available). In Russia and CIS countries 80 RON (76 MON) is the minimum available and the standard.
It should be noted that this higher rating seen in Europe is an artifact of a different underlying measuring procedure. In most countries (including all of Europe and Australia) the “headline” octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the “regular” gasoline in the US and Canada, would be 91-92 in Europe. However most European pumps deliver 95 (RON) as “regular”, equivalent to 90-91 US (R+M)/2, and deliver 98 (RON), 99 or 100 (RON) labeled as Super Unleaded.
#57
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,795 Likes
These blistering performance numbers continue to raise the question in my mind of the proper use of this car. IMO it's pointlessly fast for road use, like at a stallion confined in a small yard. At the track, it will easily 'win' in every DE run group if the driver is at least average for the run group. That means that in higher run groups, driving it at least 8/10ths will mean a blistering pace, with the associated risks, need for skill, and need for real safety equipment (6-pts, possibly halos, roll bar, cage would be preferable but impractical for street use).
#58
What did you finally decide, or have you decided yet?
#59
But that's not why we're here.
#60
