GT3 vs TTS?
GrantG----I am strongly disagreeing with your supposed facts also. Your explanations are full of info but wrong. There are many types of superchargers out there----roots, centrifugals, etc. Turbos depend on rpm to build boost also and are NOT independent of engine speed since they don't build boost at idle either and have lag also.
Centrifugal superchargers are basically belt driven turbochargers spinning at tremendous speeds when in boost.
The ZR1 being a roots supercharger of the Eaton/TVS variety, which build quick boost and more powerful on the low end of RPM(superior here to anything but the smallest turbos) and centrifugals building with RPM and having tremendous mid and top end.
I like turbos for their flexibility, but everything has its advantages and disadvantages.
Once making boost, the engine knows not what is giving it boost
Lets get on the same page here. I used a ZR1, because being supercharged. It will lose less HP at altitude that a naturally aspirated engine will. Just like a turbo engine will. Of course the ZR1 is not putting out the HP it will at sea level. Neither will a turbo.
I'll use the GT-R as an example. Race it at sea level, and again at 5000 ft.
Grantg10@aol.com
The ZR1 will lose slightly less power than a normally aspirated engine at altitude, however. This is due to the high effective pressure the intercooled supercharged motor runs at. The effective compression ratio does still fall off linearly with altitude (unlike a turbo). However since power falls off non-linearly with effective compression (a 4:1 compression motor makes effectively zero power) and an intercooled ZR1 starts very high (something like 16:1) the ZR1 will lose less power at altitude than a normally aspirated motor. It will still be far below where is is at sea level (or a turbo) however.
The Eaton is a positive displacement supercharger. Every time it turns it compresses a fixed volume of air. At sea level the incoming air is at 14.7 psi and the supercharger is turning that into 14.7 x 1.85 = 27.2 psi. At altitude with lower pressure incoming air that drops, however- 13 x 1.85 = 24 psi absolute in the intake. Hence power drops off. You can gear the supercharger up to make up the lost power (pulley or the WW2 fighter above).
If the turbo boost regulation is absolute, it's simply going to spin the turbo faster until it hits the target pressure, ie 28 psi at sea level stays 28 psi absolute at altitude. Only pumping losses, etc come into play, so the power loss is minimal with altitude. Of course lag is increased, as mentioned.
Turbo will lose FAR less than SC at altitude. I'll be happy to discuss it with you offline.
Grantg10@aol.com
Grantg10@aol.com
GrantG said turbos are independent of engine speed which is completely untrue---they don't have boost at idle either, since it runs of exhaust flow/pressure, and superchargers do not. Boost is built on RPM's just as in a supercharged motor hence the lag. One pound of boost is one pound of boost no matter what the source. Obviously they build boost different depending on the style, and yes turbos give more area under the curve and spin tremendously fast but boost is boost.
Roots superchargers are positive displacement superchargers so lets not split hairs here. Turbos are generally more efficient, but modern centrifugals have efficiencies approaching 70 percent and have the advantage of less heat formation, which is the enemy of turbos and roots superchargers which are inherent heat sinks. Modern centrifugals have step up gears built in also.
Apples to oranges, disadvantages and advantages, but a pound of boost is a pound of boost.
Remember that the quickest cars in the world run roots superchargers not turbos!
I will agree to disagree but whatever you like.
We all had our points. If we put them all together we have the answer.
I know the ZR1 was a better choice than the ZO6, but the GT3 is an even better choice.
Maybe not at my altitude. The GT2 is a better choice.
GrantG said turbos are independent of engine speed which is completely untrue---they don't have boost at idle either, since it runs of exhaust flow, and superchargers do not. Boost is built on RPM's just as in a supercharged motor hence the lag. One pound of boost is one pound of boost no matter what the source.
Have you looked at the boost curve for the BMW 3L twin turbo - makes max boost under 1500rpm. Ever see a supercharger do that on a motor that redlines at 7k?
Autobild TTS vs GT3 article. I don't know German but maybe someone who does, can translate what they concluded.
Credit to DeDe@Germancarforum.com
Yes, the engine has to be running and under load to make boost, but the turbocharger speed is far from proportional to engine speed like an SC.
You can overdrive/underdrive superchargers to do whatever you like them to do. I wonder why Top Fuelers and Pro Mods not running Turbos? Cuz they take too long to spool up and then dump the power, break parts and glaze the tires. Many times massive abrupt boost is not good at all. Superchargers also a lot easier to work on and less complex.
As I said I love turbos, buy my Novi has tremendous mid and upper range power. My GTR was great too---the best actually!
Centrifugals build boost exponentially very similar fashion to turbos. A turbo with a belt, abeit massive and overall slightly less efficient and less top speed RPM spin, but very similar.
Have you got the link for that? Chrome will translate it on a site, but not in a thread.
I'd love to read it.
I can see the tt is much faster. Look at the 0-200km/h times.
The only reason I sold the car was the fact it was noisy inside and rode rough as hell. The DCT did surge unlike PDK DCT at low speeds but at speed was phenomenal as was the rest of the car. They could refine it but they have chosen not to.
I sort of liked the whirring and sounds of the GR6, as it fit the car---big, fast, and brutal. I just didn't like the brutal part. I want refined brutality!
Those appear to be factory performance figures. Also, note the <12.0sec "time" for the GT3 0-200kph. I think this was a "first drive" comparison feature as opposed to an actual test.
They are images, so I doubt you can auto translate them.
