GT3 991 tyres
#31
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,799 Likes
^ I see the SMR as a track tire which needs heat, not an autox tire. Will likely have them on track this weekend with the Cayman R.
#32
That's what I expected too, but I overheated them on the autocross to the point that they got greasy and went off. Needed to cool the fronts with water spray to keep temps in check, and I dropped almost a second when I did that. I was surprised I overheated them so easily- never did that with the R-S3s.
#33
So far, they don't sound impressive.
Petevb, am I wrong in taking away that you prefer the MPSSs?
I like the MPSS, but they are no R-compound and the sidewalls are way too mushy for me.
#34
I suspect that with a proper alignment these tires will be very fast, but I need to get camber plates and add a degree and a half of camber to test that theory. If they are fun or tricky to drive at the limit remains to be seen. I have a feeling that you may need to be pretty tidy to make them work, which generally isn't my preference.
#35
For the street I prefer the MPSS currently, though I really need to get more camber in my car to make a fair comparison. I agree the PSS sidewalls are soft, turn-in is not sharp. If you don't like the mushy sidewall of the PSS I don't think you'll like these. So far breakaway seems more progressive and predictable on the PSS, which is something I especially value in a street tire. Normally an R compound will be better than a street tire in that respect, but with these that doesn't seem the case.
Manifold, do you have RSS LCAs on your CR?
#36
No LCAs on the CR. IIRC, front camber is 1.5, rear camber is 2.3, a little bit of front toe out, a little bit of rear toe in.
#37
