Cayman Gt3 RS anyone?!
#31
BMW has the same language. I specifically asked a dealer about tracking an M3, and the response was that all non-modded parts were still covered. FWIW, I got my secondary air pump MAF sensor replaced by warranty when the car still had decals from a track day - the dealer did not ask if CEL came on during track driving.
Very surprised to see Porsche being that way with warranty - hope it's just a cover-your-*** type of thing and they do not reject coverage most of the time.
FWIW, I have no complaints and feel confident they won't give me the runaround based on some warranty legalese. From what I've heard, my experience isn't uncommon.
#32
You probably mean passive rear steering? Practically all modern suspensions manage rear steering one way or another, even the ones with live axles. The rear steer angles are pre-calculated by engineers (on a computer!) and programmed into suspensions - the only difference is that a program can be executed by either imprecise and slow-reacting bushings and links or a more precise and direct electric motor. In either case it is just executing a program built in by engineering when the vehicle is designed. It's like slide ruler vs. calculator - ideally same inputs should result in same outputs, except the mechanical ruler has lower precision and limited useful range.
#33
^^^This! If they made that car, I'd walk away from my .2 in a heartbeat. I have dreamed of a car like that since the first time I drove a 911 and CS back to back.
#36
Received 1,139 Likes
Plus to accommodate 50% more power the car would need bigger brakes, much more cooling capacity, some tougher drive-train components - all means extra weight.
So if Porsche ever decides to put the real GT3 engine into the cayman platform, it will probably costs as much or more than GT3 (seems similar to 960). Or, more likely, it would have lower-powered engine (compared to GT3) and weight comparable to regular Cayman S.
Corvette does look interesting, especially given the price and seemingly more track-friendly attitude, but almost everyone I know who has current gen Z06 are saying never again for one reason or another. So I would wait with adopting this new model.
#38
Basic Sponsor
I think we can keep it under $95K. Under $90K is a bit optimistic but I spent the weekend there and I truly feel we could build a car like this for you guys (okay, it won't have 475 but we can get 400/325 stock). And yeah, lighter is better and we can probably save a few more pounds here and there but with tuning, exhaust and a little BGB mojo, we can get closer to 450 at the crank. I don't have an aero solution for the car but big brakes up front, bigger master cylinder and some suede bits might keep you busy til your GT3 comes.
#39
Basic Sponsor
One such dealership, which shall remain nameless, wouldn't touch a customer's car because it had RSS control arms. It was a 997.2 Turbo and something funky was going on with the diff after a few track events and the customer chose to trailer the car 300 miles elsewhere to see if he could get a more open-minded dealership.
You can understand why some do and why some don't and at the end of the day, just keeping looking for a track-friendly service tech.
#40
Come on Peter! You know I want to build this car for you! Let's go to Suncoast and bring home the nice white base 981 I saw there on Friday and get it going! I can't wait for our next ride up through the esses in whatever else you purchase! I want to put 996 6-piston GT3 Cup calipers on the front, just like we did for our 987.2 Rolex car with the X51. Suncoast has some nice Alcantara bits in the form of a shift boot, wheel, etc.
#41
#43
Cayman is lighter and we can choose a manual right?
2800LBS should be doable and still have a car that is a daily driver.
The Cayman and 991 GT3 are all the same engine, just some different internals? So why no 475? Turbo's too? Maybe we need Cayman GT2RS version.
I don't care about the interior as long as I fit in it and its not menstrual red.
We'd need some aero right?
The rear brakes are already good? You mention front only. if you are going to change them, why not a big brake kit?
No good seats for sale in the Cayman either so after market is needed anyway.
I've since learned that if you modulate the throttle a bit in the S-es you can go faster and keep all 4 wheels on the pavement...
#44
Is there a reason why people think/assume RWS will break any more than FWS?
+1. I 'd happily prefer a 375 HP 2800lb, 6 speed, 90k car over a 475HP 3200lb, PDK, 130k car.
#45
GT3 player par excellence
