991 GT3 GT3RS and 911R
991.2 GT3RS Front Fenders fit on 991.1 GT3RS?
Old 07-11-2019, 03:01 PM
arty.pa
User
arty.pa's Avatar
Default 991.2 GT3RS Front Fenders fit on 991.1 GT3RS?
Does anyone know if the 991.2 GT3RS Front Fender Trims fit the 991.1 GT3RS?
arty.pa is offline
Old 07-11-2019, 08:29 PM
NCheok
User
NCheok's Avatar
Exclamation
I know a few of you have expressed your interest in retrofitting this. Good news is, I have successfully done it and shared all of the information with JCR, he will be looking at bringing this to market soon.
NCheok is offline
Old 07-11-2019, 09:28 PM
FogCitySF
User
Does it look like it lets more air flowing from the wheel well though? The .1 RS ones have a plastic section (not the mesh, but a part that is closer to the lower part of the vent adjacent to the hood) that blocks some air.
FogCitySF is offline
Old 07-12-2019, 01:52 PM
arty.pa
User
arty.pa's Avatar
Oh wow. So there are some modifications you need to do? Can you share all the information here?
arty.pa is offline
Old 07-12-2019, 02:18 PM
kaboobie
User
kaboobie's Avatar
Looking at the Porsche parts bin, only the louvers, tapping screw and speed nut has different part number between get1 and gen2 all other components are the same.
kaboobie is offline
Old 07-12-2019, 06:32 PM
NCheok
User
NCheok's Avatar
Kaboobie is right, it also took someone to be the first one to attempted it.
Apart from what has been stated, basically the .1 air exhaust (louvres) are glued to the CF fenders, when removing it will be damaged or broken. So you don’t get to keep them anymore.
Reverse to install, the .2 air exhaust (louvres) then plug and play into the CF fenders. A little bit of glue should be applied to hold them in place to the CF fenders, not a must, just my recommendation.
And then you will have .2 air exhaust (louvres) like me on your .1 3RS.
NCheok is offline
Old 07-13-2019, 01:24 AM
Surgio
User
any photos can share?
thanks
Surgio is offline
Old 07-13-2019, 09:30 AM
kaboobie
User
kaboobie's Avatar
Nice, I'm planning to replace the whole bonnet and louvers. The pipe to cool the brake is a bit tricky to figure out. Did you do the bonnet too or just the louvers?
kaboobie is offline
Old 07-13-2019, 07:01 PM
NCheok
User
NCheok's Avatar
Question
I have the same plans as you.
I’ve bought the .2 3RS bonnet from RShanholtz and buying the bits and pieces from Suncoast for the brake ducts to work.
What makes you think the ducting is tricky? These are the parts Suncoast recommended I should get, however I am not getting #1 #2 #3 #4 at the moment as I will try and figure out whether my OEM ones can be cut once I have the rest of the ducting pieces in place.
NCheok is offline
Old 07-16-2019, 11:14 AM
kaboobie
User
kaboobie's Avatar
If you look where there pipe are hooked up, there is only one place at the new mud guards and nowhere else. I wonder if there are other place to secure it. That’s also why I think you would need the new mud guard. Since there is a hole on each side at the front I think the wind flow/aero will be affected some how so I also prefer not to have the holes but looks like I have no choice. Will have to look into that at the time of the installation.
kaboobie is offline
Old 07-16-2019, 07:38 PM
NCheok
User
NCheok's Avatar
I hear you, because I haven't seen the .2 3RS mud guards myself and can't tell from the parts diagram, I've elected not to buy #1 and #3 which are a tat expensive at $900 a pair from Suncoast.
Will be going with cutting out those holes on my .1 3RS mud guards where the ducts end at the bottom to achieve the same outcome instead.
NCheok is offline
kaboobie (07-18-2019)
Old 07-17-2019, 11:38 AM
s4corrado996tt
User
s4corrado996tt's Avatar
Yes! DB carbon even offers carbon fiber trim .2 RS's front fender grill kit for .1 RS.
s4corrado996tt is offline
Old 07-18-2019, 01:44 AM
kaboobie
User
kaboobie's Avatar
For the same price I would buy Porsche’s OEM. The pattern and everything would match and has better resale value.
kaboobie is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
