remove center exhaust for more aggressive diffuser
There seem to be plenty of exhaust offerings that bypass the center muffler and the side mufflers for weight and sound, but I'm surprised if people are going that far, why not change out the lower bumper altogether? Similar to the 911 RSR, they moved the engine to the middle to make room for a larger diffuser, if instead of bypassing the center muffler, you remove it completely and rely on side exits, wouldn't you be able to fit a diffuser where the center muffler occupied?
I'm sure there are reasons for this, but just curious because I see akrapovic offering a full race exhaust system with a replacement carbon "diffuser" which is essentially just a cosmetic change to the lower part of the rear bumper. Just seems like there's so much more potential to do more...
Ask yourself if someone driving a street car (even on a race track during HPDE) will see benefits from a larger rear diffuser. Outside of bragging rights, that is.
Also the stock center exhaust is part of the diffuser... A lot of people don't realize this. When they remove it to put in an aftermarket center bypass, they are removing aero.
Yeah you're right. Looking at photos from other threads of the exhaust area, the center muffler is pretty thin. Probably not enough area to make a big difference if the cavity were exploited for a diffuser.
Anybody have a windtunnel...
Cheers
there’s this, although bumper needs to be cut and exhaust needs to be tucked:
MovingChicane (07-22-2019)
https://www.instagram.com/p/BztS_VCl...d=v62jbljz60v3
Our cars have enough grip in the rear. We need more front grip. No point in doing a more aggressive diffuser, especially for a street car.
Assuming this diffuser extension actually works as intended.
Of course you can also achieve the same thing with the high downforce position of the rear wing, but this causes some drag...
If driven on the street a more aggressive diffuser will get trashed...plus you will not feel any benefits I will say. At the track on 120mph sweeping corners...then you will feel benefits is the diffuser is properly designed in an air tunnel to take advantage of air flow under the car.
This picture shows exactly what I was initially wondering. If you remove the center muffler and just let the exhaust exit straight out from the cats, you can clear our the entire center section. The extended diffuser from the photo looks like the diffuser in open flap mode from a 488
As folks have said, our cars probably have enough rear grip, but perhaps for the wingless GT3s, this might be an option to make up for the loss of a wing?
