Porsche GT3 RS vs McLaren 600LT
#61
So this is kinda like the NFL with any team able to win on any given day...with these cars given their extreme performance abilities any of these cars can be faster than the other on any given day.
#62
#64
The McLaren's advantage is straight line speed, it will simply accelerate harder with the extra HP and torque and lighter car.
Porsche's advantage is braking and around corners.
But that's also the difference between a pro and a amateur. Any monkey can make a car go really fast on a straight line, but pros can go around corner much faster, and probe the limits of the car, average amateur don't corner hard enough to show the cornering advantage of the Porsche, they will ended up driving around a corner about the same speed in both cars.
#66
Hopefully, that’s not why you buy a car. With that said my RS is rarer than most Mclaren’s and seems to draw a lot of attention with those who know what it is.
Tires aren’t everything guys. If they were we could put cup 2 R on a minivan and make it faster than most cars. Mclaren’s are great performers no doubt but the negatives of ownership greatly outweigh the advantages.
#67
38 Manufacturer Communicationsfor 2018 PORSCHE 911 GT3
FILTER MANUFACTURER COMMUNICATIONS BY AFFECTED COMPONENTSAll (38)AIR BAGS (3)BACK OVER PREVENTION (2)ELECTRICAL SYSTEM (5)ENGINE (2)ENGINE AND ENGINE COOLING (4)EQUIPMENT (7)EQUIPMENT ADAPTIVE (1)FUEL SYSTEM, GASOLINE (3)POWER TRAIN (1)SERVICE BRAKES (1)SERVICE BRAKES, HYDRAULIC (1)STRUCTURE (5)SUSPENSION (1)VISIBILITY (4)WHEELS (5)
February 25, 2019 MANUFACTURER COMMUNICATION NUMBER: 122-J5W5T-03
Components: VISIBILITY
NHTSA ID Number: 10155086
Manufacturer Communication Number: 122-J5W5T-03
Summary
Rear View Mirror Falls Off the Windshield
3 Affected Products
1 Associated Document
Request Research (Services fees apply)
December 14, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-C7B2H-01
Components: EQUIPMENT, WHEELS
NHTSA ID Number: 10153562
Manufacturer Communication Number: 122-C7B2H-01
Summary
Subject: Magnesium wheels
Information: The demand for the equipment option "Weissach package" was significantly higher than
originally calculated. This resulted in supply bottlenecks, for example, for the supplier of the
magnesium wheels contained in this package.
1 Affected Product
December 12, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-U4G4A-01
NHTSA ID Number: 10153564
Manufacturer Communication Number: 122-U4G4A-01
Summary
Subject: Air conditioning
Symptom: Complaint about "knocking noises" from the underbody area.
3 Affected Products
November 20, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-E6U4B-12
Components: POWER TRAIN
NHTSA ID Number: 10153573
Manufacturer Communication Number: 122-E6U4B-12
Summary
Subject: Shift lever
Information: The shift lever can move in longitudinal direction during load changes in 4th gear.
16 Affected Products
November 16, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-C9S9Q-12
Components: WHEELS, SERVICE BRAKES, HYDRAULIC
NHTSA ID Number: 10153577
Manufacturer Communication Number: 122-C9S9Q-12
Summary
Loose M6 Screws Securing PCCB Rotors to Wheel Hub
4 Affected Products
October 23, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-G6G3Q-11
Components: STRUCTURE
NHTSA ID Number: 10147454
Manufacturer Communication Number: 122-G6G3Q-11
Summary
Subject: Moulding for side window
Concern: There is a possibility that the wrong lubricant was used for fitting the side windows.
If this is the case, there may be a chemical reaction and this will damage the coating on the moulding.
2 Affected Products
September 7, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-Q5H6W-10
NHTSA ID Number: 10145556
Manufacturer Communication Number: 122-Q5H6W-10
Summary
Information: Due to amanufacturing error, there is a possibility that the front screws for securing the rear
axle struts to the body do not meet the required specifications.
As a result, the front fastening screws can break over the service life of the vehicle.
Remedial
Action:
Replace front fastening screws on rear axle struts
2 Affected Products
August 17, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-D4X2J-09
Components: ELECTRICAL SYSTEM
NHTSA ID Number: 10148788
Manufacturer Communication Number: 122-D4X2J-09
Summary
Customer Concern
The customer receives a call from the Porsche call center as if the airbag has deployed and the vehicle made an e-call. No such airbag deployment or e-call occurred. This is a false alarm.
Technical Background
This issue results from a conflict between the airbag module and Vodafone telematics service. A future additional Porsche AG action may also correct the issue.
1 Affected Product
August 16, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-Y9K4F-09
Components: WHEELS
NHTSA ID Number: 10148784
Manufacturer Communication Number: 122-Y9K4F-09
Summary
Symptom: During and after race track use, loud noises can sometimes come from the wheel assembly on the rear axle - particularly on bends.
Cause: Particles of dirt on the contact surfaces can cause micro-movements in the wheel assembly on the rear axle (rim/brake disc/wheel hub) and this can result in loud noises.
Remedial
Action:
In the event of a customer complaint, clean the wheel assembly on the rear axle as described under "Work Procedure".
8 Affected Products
August 16, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-D7K9V-09
Components: ENGINE
NHTSA ID Number: 10148783
Manufacturer Communication Number: 122-D7K9V-09
Summary
Complaint - Incorrect Allocation of Fault Code (P0153/P0133) for Oxygen Sensor
(upstream of Catalytic Converter): Replacing both oxygen sensors (upstreamof catalytic
converter) (89/18)
8 Affected Products
July 20, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-W9X4Z-08
Components: SUSPENSION
NHTSA ID Number: 10143833
Manufacturer Communication Number: 122-W9X4Z-08
Summary
Customer Concern
The customer states that the front axle lift function is not working.
The front strut leaks air. A tool with minor damage at the supplier was causing minor damages to struts during production.
5 Affected Products
July 20, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-B2S6Q-08
NHTSA ID Number: 10143834
Manufacturer Communication Number: 122-B2S6Q-08
Summary
Bubbles are caused by contamination during the paint process.
Service Information
There is no paint repair solution. The carbon fiber components with the issue must be replaced.
1 Affected Product
July 5, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-M2N8X-08
Components: FUEL SYSTEM, GASOLINE
NHTSA ID Number: 10143830
Manufacturer Communication Number: 122-M2N8X-08
Summary
Subject: Electric fuel pump
Information: There is a possibility that a fuel pressure control valve with a characteristic that does notmeet
the required specifications was installed in the fuel pump on the affected vehicles.
If this is the case, the valve will open too early and the fuel pressure will fall below the specified minimum
pressure. This can result in a reduced fuel supply and the Check Engine light may be activated.
1 Affected Product
June 6, 2018 MANUFACTURER COMMUNICATION NUMBER: 122-J7H9T-07
Components: EQUIPMENT, EQUIPMENT ADAPTIVE
NHTSA ID Number: 10143514
Manufacturer Communication Number: 122-J7H9T-07
Summary
Symptom: The plastic rear window can become damaged or part of it can become visibly detached from the body due to different temperatures and tension while driving.
This can cause wind noise.
Cause: The components of the rear window ? plastic (polycarbonate), screen print and primer ? are not chemically compatible.
4 Affected Products
You get the idea?
#68
But that's my point. Flared arches would allow Mclaren to run a wider front if they chose. It's not a limitation of the tub as is usually claimed. porsche have been doing the same to increase front track width on the GT cars for years after all.
#69
OK, makes sense. I guess they could add flares if they chose to do that (maybe they will at some point, but if not in LT then where?)...
#70
I don't know. Perhaps they reckon the cars are quick enough (which would be entirely correct) without needing to compromise road manners further. Ok it's not exactly a like for like comparison but just look at the latest Schmee video. The Senna even with 245 fronts has obliterated the Manthey 2rs with Cup2 R's time at Spa. And that was with a customer car not a factory one.
#71
Correct, not like for like. 3x the price should be faster... I wonder how the new hybrid 1,000ps Ferrari will compare (it's rumored to be half the price of the Senna, but not as light and track focused).
#72
Originally Posted by CRex
McLarens at this point do not belong to the same sentence with "reliability" or "quality". Argue what you may, show me an LT/S that can last a whole trackday weekend without a fuss and I'll STFU.
#73
You can show us all the reported problems for Mclaren too. It’ll surely be more extensive. I can tell you from my experience that Porsche in general is much more reliable than Mclaren. If you don’t agree that’s ok as I could care less. Go to any track event and ask any serious driver and most will concur.
#74
#75
We missed you out there. I thought you would've showed up for sure -
