2016 GT3 RS Dyno-ed with Dundon Race Headers + JCR Center Bypass
for those of you who don't know, i had a 2015 991.1 GT3 equipped with Akrapovic full system then switched to the dundon race headers and got better power, you can see the thread here https://rennlist.com/forums/991-gt3-...vic-setup.html
fast forward three years later, now i own a 2016 991.1 GT3 RS, from day 1 i put the dundon race headers on it and JCR center bypass... this setup sounded great to me while driving (no drone) and was very aggressive. However, from outside of the car it was very loud.. too loud if you get what i mean... my friend's all said your car sounds like a heavy modified mustang not that there is anything wrong with that but it was too loud for me and the car would just get too much attention from the loudness
i only noticed this when i let a friend take the car out for a rip while i was sitting at a coffee shop, at that moment i decided better to return the stock center muffler (until i order the black lifetime dundon center muffler), so since i was going to do this i said i might as well dyno this take videos and share results with all to see and luckily enough i had a friend come along with his stock 2016 991.1 GT3 RS to join in on the dyno
here is a run of Dundon + JCR combo
here is a run of Dundon on its own
now that the videos are done, let us share the results, first up is my friend's stock RS
i know it is not my car but at least we had a stock RS on the dyno to use as a baseline, next up is my car with the combo of JCR + Dundon (keep your eye on the graph)
Above shows some gains over stock RS and below 3 runs shows consistency
We removed the JCR and went back on the dyno without even driving it around, gave it a couple of dyno pulls then came the numbers
it just got better and better after each pull also notice the graph is much better than when i was running the combo together
Here you can see comparison between the combo set (highest HP pull) and the current setup (best 2 runs) along with graphs showing power advantage to dundon on its own and better power band in mid range to peak
If you compare my friend's stock RS numbers with the current setup on my car now (dundon + OEM center) you will see gains at peak of about 20 whp & 10 wtq
what matters to me is the DELTA and not the numbers per say these were done on a Mustang Dyno they are not all calibrated the same, so the point of bringing the stock RS was to do a baseline number and see the DELTA with the different setups
i would like to say that both companies make superior products and the quality / finishing is spot on, the two systems are not made to go together, each on their own has advantages depending what you are looking for
if you are looking tor a center bypass then i highly recommend JCR and if you are looking for long tube headers that delete the side mufflers then for sure you need to reach out to Dundon
Thank you for sharing. It will be interesting to see dyno numbers comparing Dundon headers to the new JCR headers.
For what it's worth dundon headers on a 991.1rs bring the power close to a stock 991.2rs?
I cant wait till dundon releases their intake setup so we can get near 500hp on a 991.2rs
Basic Sponsor
We're at 492whp on the 991.2 RS as the current watermark, the new "Crack" pipe Megaphone Center Delete may help push it up a bit so 500whp isn't far away...
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
Originally Posted by bogey1
Thank you for sharing. Great thread. I am trying to figure out which way to go on my 2016RS. I know one thing for sure, it will include parts from the guys at Dundon.
Originally Posted by dxbtousa
Nice info and numbers mate - thanks for sharing.
dundon (black) center muffler with tips arrived earlier today
i decided to weigh the DMS muffler vs. the stock RS muffler ~ difference is 7 kgs
DMS muffler above & stock .1 RS muffler below
JCR super light tips can't be installed on the muffler that arrived today, i decided to weigh the tips ~ difference is 250 grams
JCR super light tips above & dundon tips below
should be installed later today
Ducati1199 (06-25-2019)
Basic Sponsor
The scales are off a good amount on the smaller measurements, our Superlight Tips are 0.46kg and the OEM Titanium Centre is 5.54kg
JC
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
JC
JC
i assume though the delta would be the same either way the super light tips don't fit the new muffler
FYI: I have a 911.1RS Dundon orange muffler and D race headers and tune. The other day I was fortunate to drive two cars on the track for a few laps each. A 991.2RS with Dundon black muffler, D catted headers and tune and a completely stock 991.2RS. I was quite surprised that my car was noticeably faster than the stock 991.2RS. The owner even thought my car was faster to the point that after driving my car he wanted to immediately mod his car. The other car with black muffler, catted headers and tune were I'd say was like a step faster like mine was to the stock gen2. I thought the difference were a lot and the the stock gen2 would be faster than my car but that was not the case and after the tune the difference is not as bad as I thought.
having said that who did your tune?
Hi GT3KSA,
While my car did not show any lights before the tune, after the tune the response was much better, and it is livelier in the lower RPM range. (below 4000). I had Autowerks who is a subsidiary/partner (not too sure of the arrangement) of McChip in Thailand did it. The other .2RS also had it done there.
https://mcchip-dkr.com/en/chiptuning...=carselector#0
I have the dyno before and after the tune in my car. I'll take a pic for you if you want to see it.
Hi GT3KSA,
always interested to see before / after dyno results
