Guide to removing 991.1 GT3 RS Roll Cage
anyone posted a guide as mine is going into storage next week, when my car arrives, I dont need to carry that amount of extra weight on the street
I would think its pretty straight forward depending on the roll bar. some require more interior trim pieces to be removed along the side (cantrell) whereas others (BBi) do not.
Both seats need to come out and then the carpets...in order to get access to the bolts.
roll bar probably only weighs 20 kg or so...not sure you would even notice, particularly on the street...unless this is part of a bigger weight reduction plan...
So its out, took me about 4 hours as I went slowly and carefully, I guess it weighs circa 60lbs, this guide helped https://cantrellmotorsport.com/wp-co...-WITH-PICS.pdf
Thanks for the photo Richard.
The NA cars need a mounting bracket to accept the front legs.This link shows the installation of a replica clubsport cage on a NA car:
https://www.agencypower.com/blog/age...rsche-991-gt3/
I am wondering what the ROW cars' front mounting points look like? Same bolt in brackets or factory weld on plates?
s4corrado996tt (07-16-2024)
i have taken mine out to paint this week.
Any pointers on fitting back into the car please. Did you install the side panels first then the cage. The cage front base plates need to go under the rear quarter panels, looks like it will be not easy.
Thank you.
So far what I did:
1. Took out panel C covers.
2. Removed rear carpet and rear center console trim.
3. Unbolted the two long top corner screws that connect two main parts of the cage.
4. Removed all 3 screws on each 4 legs of the cage (the ones that attatch to the chassis).
I tried to:
1. Remove panel B trim (first I had to remove the top trim where seat belt comes out of the pillar). IT IS IMPOSSIBLE THERE IS NO SPACE TO PLAY!!
2. Taped panel B base so that I dont damage the trim when removing the cage.
And..... no success so far. Please, can you post your steps?
Regards,
Edson.
Hi Richard, I am in the same spot. I want to remove the cage of my 991.2 GT3 RS. Already tried without success.
So far what I did:
I tried to:
Regards,
Edson.
So far what I did:
I tried to:
Regards,
Edson.
it was not obvious for me, have you pulled the round disks off around the top of the cage. Behind are hidden screws to separate the cage in two. Then you can slip the side panels away.
edsonreds (06-24-2020)
1. To retire the diagonal part of the cage, it is not only necessary to unbolt each "leg" right? Did you have to remove the "foam" that protects the circuits and cables at the bottom? or just wiggle the way around?
2. I managed to pull off the Pillar C trim, which are the small side panels near the read window. In order to take out the panel when the speakers are attached: I must retire the trim when the belts come out, am I right? Just then I can pull up the Pillar B trim (where speakers are located)? In that case I will have to finally slide backwards the Panel B trim, right?
Sorry for so many questions.
Regards,
Edson.
Roll cage 991 gt3
Thanks for your answer man. Yes, unbolted 2 screws which held in place a short "sleeve". Once you slide it off, the diagonal section gets separated into two parts. One big part (left part) and one small (right part) which is like a post. Along with the top corner bolts, that means the cage gets finally separated into 3 parts, right? Some questions to that matter, please:
Regards,
Edson.
Regards,
Edson.
