RS Speed Custom Titanium Exhaust?
Candidly the quality of manufacture of most aftermarket exhaust system ranges from acceptable to worse than poor. But, you get what you pay for. Truly first class fabricating is expensive, i. e., a high quality component would cost three or more times what standard commercial aftermarket vendors charge. Further, if I had to name the highest quality fabricators/welders in the country, I would have a hard time naming more than one. As to the piece of which you posted a picture, my advice would be to look elsewhere.
I am curious as well?
I had an IPE exhaust in the past and now JCR. With the valves opened the IPE is basically the same straight pipe, the only difference is the longer length from the loop design of the JCR. The JCR pipe is way higher pitched. X-pipe changes the tone of the sound also as you mentioned. This is why GMG/sharkwerks sound different than BBI/GR/CMS rear bypasses. In addition to these things, the thickness of the titanium contributes to the differences in sound also.
I think you might be confusing pitch and timbre. Ever see a pipe organ? Same thing.
All of these things you're talking about affect timbre and tone. Not pitch. Except the length of pipe. RPM will certainly affect exhaust pitch. But other than that, the length of the exhaust should function the same as a trumpet or trombone or didgeridoo, or any other wind instrument. The longer a tube's length, the lower its fundamental frequency. It's possible to coax higher tones out of a pipe than it's fundamental though. The material it's made of and the merge/collector design will affect tonality.
The one absolutely brilliant fabricator I know does not do retail or repetitive commercial work and does not wish publicity. If I gave my opinion of quality of manufacture, I am sure I'd by stoned by many factions. I should, however, note that quality of manufacture does not include sound which is totally subjective nor does it include HP or torque as that is design engineering although an excellent fabricator is usually good at design but it does include weight, strength and longevity and elegance.
Regardless of the pitch argument, I think we can agree that all of these sound awesome
https://www.instagram.com/p/Bwyrc1zlUAv/
https://www.instagram.com/p/BwWu2aAFYvx/
https://www.instagram.com/p/Bvb__v7Ffvx/
Decided I'm going with the titanium race pipe but just found out they only accept bank transfers as payment i believe. That's a bummer as it's kind of a pain to go and deal with my bank for that. I contacted them to see if they accept cards or paypal but have gotten no response so far. Also Im hoping they release more data on the superlight Inconel headers they have and their tune too as I most likely will want to get them too.
