15 GT3 with high copper in oil
After 2 track events over 5 days my local P car Indy noticed a lot of copper in the oil. I spoke to my local dealer and they need to do their own sample and told me to go to my next event which is tomorrow at lime rock.
I don’t have an actual cooper count but Sam from Elite knows his stuff. I will view the sample later today. Only copper parts are the main bearing and rod bearings correct? My car has the original engine. Any info would be appreciated. |
Michael
Motor Check the lab I user in West Palm an FYI "understanding Your Report " states for engines , Copper: Bearings, Bushings, Thrust Washers, Oil Cooler, Clutches, and oil additive in some gasoline motor oils. at or below 20 PP one million |
Originally Posted by LexVan
(Post 15826233)
What does this mean? Does your indy have X-ray vision?? Did he run a UOA??? If he ran an UOA, what's the ppm????
Well if he could see copper particles in the filter I would think the ppm would be off the charts. I'm doing my first oil change next week and a sample is going straight to blackstone.
Originally Posted by RDCR
(Post 15826260)
Originally Posted by GrantG
If it’s really bad, you can sometimes see fragments on the filter paper
