JCR // 991.2 GT2RS EXHAUST (REFERENCE THREAD)
Basic Sponsor
Hey all,
As there is no specific 991.2 GT2 RS section on the RL Forum I felt this was the most appropriate section for this post. This time, rather than separate threads for each individual product I will have this post up and update as we add products to keep everything in one place to avoid any confusion (or the admin closing threads without warning)
So, here we go again! Our next wave of Porsche products, this time its the 991.2 GT2 RS that gets our attention. Some seriously nice exhaust offerings from JCR suitable for the 991.2 GT2 RS!
I'm very excited to properly unveil these products, we have been working hard to ensure that we achieve all of the goals set our with these products. Less weight, more power, great sound!
We will be updating this thread often with new releases and updates, along with video and further media.
As always, any questions please do feel free to ask!
JC
CENTRE SILENCER REPLACEMENT PRODUCTS
Each of the JCR 991.2 GT2 RS Centre Silencer Replacement products are direct replacement for the OEM centre silencer and come supplied with all necessary mounting hardware. All centre silencer replacement products are produced from ultra high grade Titanium ASNEX and are also supplied with bespoke Titanium clamps which are not only lighter than the OE steel versions but also create a more solid seal from the cats to the centre.
Titanium Non Silenced Centre
Description
A direct replacement for the factory centre silencer maintaining the OEM diameter. Light weight option with zero silencing, maintains the OEM diameter to avoid any unwanted drone but increases volume compared to the OEM centre silencer with valves in the closed position.
Integrated in the design we have a centre merge to accentuate the exhaust tone.
Key Features
Titanium Silenced Centre
Description
A direct replacement for the factory centre silencer maintaining the OEM diameter. The silenced version includes a bespoke titanium silencer that gasses are directed through when the valves are in the closed position.
Key Features
OEM VALVED CAT REPLACEMENT PRODUCTS
Each of the JCR 991.2 GT2 RS OEM Valved Cat Replacement products are direct replacement for the OEM valved cat assemblies and come supplied with all necessary mounting hardware. All JCR valved cat replacement products are produced from ultra high grade Inconel 625 and OEM spec exhaust valves by Helical.
Inconel Valved Race Cats
Description
A direct replacement for the factory valved cat assemblies. Replacing the OEM catalyst with a 200cel Race Cat from HJS and increasing the size of the OEM exhaust valve from 68mm I/D to 76mm (22% increase) for dramatically increased flow. The combination of these two factors lead to quicker turbo spool, improved response and significantly less back pressure resulting in increased performance.
Due to the retention of catalysts this product will not trigger a CEL, will pass emissions and no additional ECU tuning is required.
Key Features
Inconel Valved Cat Deletes
Description
Due to deleting the catalysts this product may trigger a CEL, and additional ECU tuning may be required to avoid such instances.
Key Features
OEM EXHAUST CLAMPS
Each of the JCR Titanium GT2 RS Centre Silencer Replacement products are supplied with our bespoke made Titanium Exhaust Clamps however for those who wish to upgrade their OEM steel exhaust clamps we have made these products available separately.
Description
A direct replacement for the OEM Porsche steel exhaust clamps as found on all 991.2 GT2 RS. This full titanium replacement is not only more robust but also ensures a tighter seal from the exhaust components to avoid any movement or leaking.
Key Features
And some examples of the products built up below.
In this example we have our Inconel Valved Race Cats combined with our Titanium Silenced Centre.
And some close up shots. Just because..
JC
Description
Key Features
- 100% Titanium ASNEX Construction
- 2.26kg (4.98lbs)
- 991.2 GT2 RS
- £2095.00 GBP
- Available Now
Description
Key Features
- 4.06kg (8.95lbs)
- 991.2 GT2 RS
- £2595.00 GBP
- Available Now
Description
Key Features
- 100% Inconel 625 Construction
- 7.06kg (15.56lbs)
- 991.2 GT2 RS
- £3450.00 GBP
- Available Now
Description
Key Features
- 991.2 GT2 RS
- £2650.00 GBP
- Available Now
OEM EXHAUST CLAMPS
Description
Key Features
- 100% Titanium Bespoke Clamps
- 0.58KG (1.27LBS)
- SS High Quality Clamps
- 991.2 GT2 RS
- TBC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
Hey JC, any sound clips on these systems?
Which ones avoid the ECU remap?
Really only interested in the best sound and no ecu work as power isn’t a issue with these beasts and don’t want warranty issues.
Thanks!
Thanks!
