991 GT3, GT3RS, GT2RS and 911R 2012-2019
Racelogic VBOX; Anyone know Canbus cable 2019 GT3RS?
Old 04-01-2019, 09:01 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,583 Likes on 732 Posts
Default Racelogic VBOX; Anyone know Canbus cable 2019 GT3RS?
Thought we knew. Don’t work.
Racelogic / VBOX UK doesn’t know.
Old 04-02-2019, 09:09 AM
goldberg
goldberg's Avatar
This would be handy!
Old 04-02-2019, 11:54 AM
daveo4porsche
daveo4porsche's Avatar
Received 3,599 Likes on 1,757 Posts
are you asking about the "physical cable" or the CAN Bus data settings for the Racelogic?
Old 04-02-2019, 02:02 PM
TRAKCAR
TRAKCAR's Avatar
Yes, I have it connected.
Wont work.
on my 991.1 it was this cable
Old 04-02-2019, 02:51 PM
daveo4porsche
OBD will NOT work with Porsche for race logic - you have to physically splice into the CanBUS - I have that setup working on my 991.2 as seen here in this video
in the video, RPM, Steering Angle, gear (only works in automatic mode not manual I'm working to fix that) and brake and throttle are all coming from CAN BUS in a 991.2 into my Racelogic VideoHD2 unit - all other data (speed and lap times and such, g-force, are coming from the Racelogic's internal data sources.
you need this cable
https://www.vboxmotorsport.com/store...product_id=101
BR Racing did the actual splicing for me - they might be able to help you - 408-356-1515
Old 04-02-2019, 05:51 PM
nolimits
nolimits's Avatar
CAN bus is necessary, but you don't need to splice, just get induction cable connection, comes on and off easy if needed. At least from a 991.1 TTS perspective.
Old 04-02-2019, 07:43 PM
TRAKCAR
TRAKCAR's Avatar
What does the Canbus wire we need to tap look like?
What color?
Old 04-02-2019, 08:30 PM
daveo4porsche
we tried this and it didn’t work - do you have this actually working on a 991 porsche - racelogic also confirmed they know of no circumstances where induction works.
Old 04-02-2019, 11:52 PM
nolimits
nolimits's Avatar
Yes, picking up rpm, brake, and throttle using their snap induction clamp cable (no splice or punch through insulation) fitting over the twisted CAN wires in bundle by fuse box. FYI this is for a PDK trans.
Devan at Racelogic gave me info when HD2 came out. The CAN wiring I think I found at the AIM site back then.
Wiring in my car:
A20 Orange/red twisted CAN High CAN+
A10 Orange/brown twisted CAN Low CAN-
Old 04-03-2019, 12:33 AM
aalencar
aalencar's Avatar
I think there is a difference between 991.1 and 991.2. It took me multiple tries to figure it out on my 991.2 GT3. I have MT and it captures everything but gear position. Working with Racelogic to figure it out but no luck so far. They are using some calculations to guess gear position based on engine speed but not really working. Almost there though.
As daveo4porsche mentioned, I was not able to use OBDII CAN Cable or Clip-On CAN Bus Interface. The only thing that worked for my car was the Unterminated CAN Interface Cable.
The picture attached is crappy but the blue from HD2 is connected to orange/purple (CAN High) and white from HD2 connected to orange/brown (CAN Low). Both wires are on the same twisted pair.
The position in relation to the fuse box matters. I first tried to connect to the wires located between the fuse box and door and it did not work. It only worked when I connected it to the same twisted pair on the driver side footwell.
Please let me know if you need help. I can order the cable and ship your way! Will do whatever it takes to get the best data possible on your videos!
Old 04-03-2019, 06:36 AM
TRAKCAR
TRAKCAR's Avatar
^^^ Thanks aalencar!!
We got it sorted and working
Old 04-03-2019, 12:14 PM
GrantG
GrantG's Avatar
Received 4,701 Likes on 2,682 Posts
Nice going!
Old 05-09-2019, 03:48 PM
SanDiegoDavid
SanDiegoDavid's Avatar
So Peter, do you have a pic of the connection? Trying to accomplish the same thing.
Old 05-09-2019, 08:33 PM
Hams955
Hams955's Avatar
Wont work.
Did you end up flipping the wires in the harness? You had the correct ones.
Last time I installed in my car this was my problem. Couldn't get a read from the CAN. Flipped them inside the harness and worked just fine.
- Chris.
Old 05-10-2019, 09:11 PM
SanDiegoDavid
- Chris.
Chris, You were able to use the clip on induction cable? And what do you mean by flipping them inside the harness? Sorry about my ignorance, just trying to get this working in my .2 RS.
David
Quick Reply: Racelogic VBOX; Anyone know Canbus cable 2019 GT3RS?
