Center Lock removal w/ this....
If you want an impact solution install 991 cup center locks on your car.
It’s doable. And will take an impact wrench. Not inexpensive...
Otherwise just deal with this crap like everyone else does. yeah, it sucks.
Or
Feel free to short cut it and post back here when you’ve lost a wheel at 150mph.
Or
just out of curiosity, does the cup car have steel CL nuts then?
Stub axles are about $350 each and the washers are $80 each from Porsche Motorsport. I think the nuts are around $75 IIRC but have a good service life.
We need a cordless electric torque gun which has a counter hold arm.
This is how the factory does it, as shown in this youtube clip. The below youtube starts at the wheel nut installation - 27:20 mark.
They aren't cheap, but if you can find them under 1K it might be worth it. I can't find anything under 1K.
http://www.torcup.com/product/vt-series/
http://www.globalminingproducts.com/DVRAD1000.html
If those don’t have the hammering impact action, then it could be a very interesting option!
Pretty sure the tool used in the Porsche video is at least 5-figures and you can see that it tightens from inside the splines of the locking mechanism (rather than on the outside of the CL nut). This requires a totally different attachment than the one we use (that comes with the car). You can also hear that there is no hammering in the Porsche vid.
The smallest of those Torcup wrenches in your first link costs $5,200:
These impact tools has evolved from generating not much torque, hard to hold, noisy to easy to hold, quiet, much more powerful in the past few years. Milwaukee is now offering their 4th Generation of M18 torque wrench and use oil to dampen the impact and are much quieter and a lot easier to hold onto, they don't "impact" like the older models I have. The top specs models all have 1500+ Ft-Lb of loosening torque which is enough to take apart any suspension and engine bolts that are rusted (or break them). Since now these guns produce more than enough torque for almost all non-heavy-industrial jobs, the design direction may go to making these guns quieter, easier to hold and softer and softer on impact. I just am not sure if these Gen 4 Milwaukee guns are soft enough for the job and thus asked the forum if anyone has tried them.
https://youtu.be/z3zuPyjFTsk?t=1640
"DV-RAD-1000 torque 400-1000 ft./lbs. Driver size 0.75” and RPM 7.7 $6,600USD ea.
DB-RAD-1000-2 torque 250-1000 ft./lbs. Driver size 0.75” and RPM 19 $7,750USD ea."
So, not exactly a bargain solution (but it does seem like a possible solution for a shop, particularly if one can find that internal splined attachment)...
They don't wear out as quickly as you'd think. The parts that I keep regular spares are for the stub axles and the wheel washer between the nut and wheel. Those parts tend to fail often.
What is the washer? I don't see it in the PET for Cup or street cars.
How many hours do you get on these components?
https://rennlist.com/forums/porsche-...-assembly.html
Thanks for any insight!
