991 GT3, GT3RS, GT2RS and 911R 2012-2019
Center Lock removal w/ this....
Old 03-05-2019, 09:09 PM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
If you want an impact solution install 991 cup center locks on your car.
It’s doable. And will take an impact wrench. Not inexpensive...
Otherwise just deal with this crap like everyone else does. yeah, it sucks.
Or
Feel free to short cut it and post back here when you’ve lost a wheel at 150mph.
Old 03-05-2019, 09:22 PM
Hams955
Hams955's Avatar
I use that gun to remove/install the CL nuts on my cup car. It works fantastic FYI. Definitely worth the purchase.
That said - I wouldn't use it on the street car CL's.
- Chris.
Old 03-05-2019, 11:09 PM
Sunny_M3
Sunny_M3's Avatar
Just go to a Porsche dealer or experienced shop to do whatever you need that involves removing your wheels. It'll save you time and pain.
Old 03-06-2019, 09:55 AM
goldberg
goldberg's Avatar
I personally would not use this.
that hammering action is the killer
Old 03-06-2019, 10:34 AM
mchrono
mchrono's Avatar
just out of curiosity, does the cup car have steel CL nuts then?
Old 03-06-2019, 11:04 AM
Hams955
Hams955's Avatar
Yes and the drive pins are different as well. The system is designed to handle impact guns and lower torque rating as well.
Old 03-06-2019, 11:48 AM
GrantG
GrantG's Avatar
Received 4,721 Likes on 2,691 Posts
Even so, I've seen Cup Cars at the track whose CL's look pretty torn up from the impact wrench. I would guess they don't last too long, but at least the wheel changes are painless.
Old 03-06-2019, 12:34 PM
Hams955
Hams955's Avatar
They don't wear out as quickly as you'd think. The parts that I keep regular spares are for the stub axles and the wheel washer between the nut and wheel. Those parts tend to fail often.
Stub axles are about $350 each and the washers are $80 each from Porsche Motorsport. I think the nuts are around $75 IIRC but have a good service life.
Old 03-06-2019, 01:23 PM
abiazis
abiazis's Avatar
Great info...thanks...
Old 03-06-2019, 07:09 PM
sl951
sl951's Avatar
We need a cordless electric torque gun which has a counter hold arm.
This is how the factory does it, as shown in this youtube clip. The below youtube starts at the wheel nut installation - 27:20 mark.
They aren't cheap, but if you can find them under 1K it might be worth it. I can't find anything under 1K.
http://www.torcup.com/product/vt-series/
http://www.globalminingproducts.com/DVRAD1000.html
Old 03-06-2019, 08:10 PM
GrantG
GrantG's Avatar
If those don’t have the hammering impact action, then it could be a very interesting option!
Pretty sure the tool used in the Porsche video is at least 5-figures and you can see that it tightens from inside the splines of the locking mechanism (rather than on the outside of the CL nut). This requires a totally different attachment than the one we use (that comes with the car). You can also hear that there is no hammering in the Porsche vid.
The smallest of those Torcup wrenches in your first link costs $5,200:
Old 03-07-2019, 12:50 AM
bli8
bli8's Avatar
These impact tools has evolved from generating not much torque, hard to hold, noisy to easy to hold, quiet, much more powerful in the past few years. Milwaukee is now offering their 4th Generation of M18 torque wrench and use oil to dampen the impact and are much quieter and a lot easier to hold onto, they don't "impact" like the older models I have. The top specs models all have 1500+ Ft-Lb of loosening torque which is enough to take apart any suspension and engine bolts that are rusted (or break them). Since now these guns produce more than enough torque for almost all non-heavy-industrial jobs, the design direction may go to making these guns quieter, easier to hold and softer and softer on impact. I just am not sure if these Gen 4 Milwaukee guns are soft enough for the job and thus asked the forum if anyone has tried them.
Old 03-07-2019, 12:51 AM
bli8
bli8's Avatar
I'm all in at $520, oh wait... I missed a zero.
Old 03-07-2019, 01:48 PM
GrantG
GrantG's Avatar
https://youtu.be/z3zuPyjFTsk?t=1640
Hi I emailed the company that distributes the tool in your second link and received this price quote:
"DV-RAD-1000 torque 400-1000 ft./lbs. Driver size 0.75” and RPM 7.7 $6,600USD ea.
DB-RAD-1000-2 torque 250-1000 ft./lbs. Driver size 0.75” and RPM 19 $7,750USD ea."
So, not exactly a bargain solution (but it does seem like a possible solution for a shop, particularly if one can find that internal splined attachment)...
Old 03-17-2019, 02:32 AM
FrenchToast
FrenchToast's Avatar
How and why do the stub axles fail? Is this a Cup car or street car? (Cup and street show same P/N for stub axle).
What is the washer? I don't see it in the PET for Cup or street cars.
How many hours do you get on these components?
https://rennlist.com/forums/porsche-...-assembly.html
Thanks for any insight!
Quick Reply: Center Lock removal w/ this....
