Exhaust changes for weight loss only
Would you mind posting a video? Would like to hear.
Appreciate all the thoughts.
What about the titanium rear muffler from the RS? I assume that can be easily swapped with the GT3 version? Anyone know how much weight that saves with that one mod by itself?
I agree...I have Soul Side Muffler delete pipes. Great quality product. I unhooked the valves and have been driving around and really like the little bit extra sound below 4000rpm.
EDIT- though I would opt for keeping the valves, even if it costs me those 3 lbs. I thought the valves affect low end torque if I recall correctly.
About 6.5 lbs difference between gt3 & 991.2 RS center muffler, which is a revision of the 997/991.1 RS muffler
I do not feel there is a loss of low end torque with (valved) side deletes, it actually feels (or just sounds...) a little bit more alive in the lower rpm range.
Sound is not almost identical to stock to my ears, definetely louder below 4000rpm, above almost the same as stock. I like it, mainly because it
retains the stock sound characteristics and it´s not over the top, just the way a GT3 should sound. There is a drone around 3000rpm with valves open
and constant speed, none with valves closed.I also installed a remote control for the exhaust valves, which gives me the choice of mild or wild anytime.
Perfect for my taste soundwise, and even better with weight savings and less rear tire heating.
With the center muffler delete I had tried before, I could indeed sense a loss of torque. Along with that, sound was nice, but so loud that it
overlayed that glorious airbox noise above 7500rpm. Back to stock after one hour, not my defintion of sound, just noise.
Peter
Peter
Basic Sponsor
Info below could be helpful, from this you can determine the weight savings of each of the possible configurations. Safe to say that our exhaust options are amongst the lightest solutions available for this platform.
Any questions please do not hesitate to ask
JC
Manifolds / Headers
OEM (lh) = 4.38kg (9.66lbs)
OEM (rh) = 4.48kg (9.88lbs)
OEM (pair) - 8.86kg (19.53lbs)
JCR Inconel Race (lh) = 3.08kg (6.79lbs)
JCR Inconel Race (rh) = 3.13kg (6.90lbs)
JCR Inconel Race (pair) - 6.21kg (13.69lbs)
Side Silencer
OEM (pair) - 20.16kg (44.44lbs)
JCR Titanium Side Silencer Bypass (non valved) (pair) - 1.96kg (4.32lbs)
JCR Titanium Side Silenced Bypass (valved) (pair) - 2.68kg (5.90lbs)
Centre Silencer
OEM Steel - 7.22kg (15.92lbs)
OEM Titanium - 5.58kg (12.30lbs)
JCR Titanium Centre Bypass (non silenced) - 2.18kg (4.81lbs)
JCR Titanium Centre Bypass (silenced) - 2.96kg (6.53lbs)
JCR Titanium Centre Bypass (superlight) - 1.14kg (2.51lbs)
JCR Titanium Race Pipe
JCR Titanium Race Pipe (non silenced) - 4.84kg (10.67lbs)
JCR Titanium Race Pipe (silenced) - 6.82kg (15.03lbs)
JCR Titanium Race Pipe (valved) - 8.50kg (18.73lbs)
Tips
OEM (stainless steel)- 1.54kg (3.39lbs)
OEM (titanium) - 0.92kg (2.03lbs)
JCR Titanium - 0.72kg (1.58lbs)
JCR Titanium (superlight) - 0.46kg (1.01lbs)
JCR Titanium (silenced) - 1.48kg (3.26lbs)
JCR Titanium Race Silenced w/DT - 1.48kg (3.26lbs)
JCR Titanium Race Silenced wo/DT - 1.48kg (3.26lbs)
Misc
OEM Exhaust Centre Bracket - 1.67kg (3.68lbs)
JC
Manifolds / Headers
Side Silencer
Centre Silencer
Tips
Misc
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
brontosaurus (10-15-2022)
Basic Sponsor
I saved 35lbs by doing the side muffler deletes on my GT3RS. Its a definitely a little louder over 4K but like everyone says, just amplifies the stock sound and doesn't really change it much in my opinion. Plus I have the valves so you can vary the sound for what you need.
When I went thru this on my 997 the best exhaust, no drone I found was Akrapovic sports cup
i plan on putting on my rs and touring soon
my 997 has absolutely no drone, it makes a little power...had 20k hard track miles with zero cracking
it’s expensive, buy worth it
if anyone else interested maybe we can get a group buy....I’m buying thru Titan Motorsports when I finalize
https://www.akrapovic.com/en/car/pro...49&yearId=5459
Basic Sponsor
On my .2 GT3, I plan to get a lithium battery for weight loss and I'd also like to modify the exhaust for weight loss. That is where my question comes up.
I'd like to drop a decent amount of weight from the exhaust.........but in contrast to many of you guys, I'm fine with the quality and volume of sound from my .2 GT3. So I'm not looking to make the car louder, just lighter.
What do you guys recommend?
The Akrapovic Evolution Exhaust will save you just over 30 lbs in total. As many can attest Akra isn't obnoxiously loud either. They make sure to fine tune the sound so that it's only an incremental improvement over the OEM sound rather than changing the entire character of the exhaust note.
it’s expensive, but worth it
No group buy needed. As Akra's largest dealer in the U.S. I will provide anyone interested with industry leading pricing - whether you make that purchase with a bunch of friends or you do so solo
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
Basic Sponsor
From a return on investment standpoint, our side muffler bypass pipes net either 35lbs or 38lbs (non-valved $945 vs valved $1395). Deleting the side mufflers also nets a great decrease in heat soak to the rear tires, this is noticeable for track guys and is not to be undervalued. This is my favorite bang for the buck modification for the GT3 platform.
Here are some photos of the side mufflers compared to our non valved bypass pipes on our shipping scale
That said, we have also just added our Modular Competition Exhaust Package, netting 46lbs-49lbs weight savings over factory depending again on whether or not you maintain valves in the side muffler bypass pipes. This system starts at $1940 and will be released on Rennlist this week in it's own dedicated thread.
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
johng@soulpp.com
jwheel@soulpp.com
