Brake Lines for GT3/R
Does anyone make a brake line that screws directly into the calipers without the use of the intermediate small hard lines that are used at each caliper (and are different at each corner) from the factory?
Basic Sponsor
PM headed your way!
The Spiegler 6 line kit is the only way to go!
https://www.teambgb.com/product-p/spiegler991-981.htm
I had those along with the Tarett stud kit on my GT4. Much easier changing pads.
PM headed your way!
The rear Spiegler lines were replaced (back to hard lines) due to concerns about rubbing due to RWS on the 911 GTs. The rear hard lines aren't as critical as the front setup in regards to taking calipers off. Due to front turning its best if you had 2 lines instead of 1.
PM headed your way!
