991.2 air filter change
Did it myself...easy actually....I put in BMC like the RS comes with so I can clean them every year. I’d say it takes about hour tops...dealer probably 30 minutes. They probably charge hour rate plus the $70 for stock paper filters.
OP,
I meant to post this YouTube video (below), the other day...I used the video as a guide when I removed my RS’s rear cover. On a GT3 getting to the three fenderwell screws on either side can be a little tight, but it’s doable. I’m assuming jacking up the rear may help, I didn’t. Note: Not mentioned in the video, the RS has a forth screw nearly at the top of the fenderwell covered by a plastic piece.
It really is a fairly straight forward job...plus you’ll be able to appreciate what you own that much more. These cars underneath are just as beautiful.,,to me.
PM me if I can help.
Best,
JB
Best,
JB
As previously stated it’s not too bad of a job. It’s kind of fun. I’ve taken everything off in anticipation for an exhaust exchange I’ll be doing. I’ve exchanged the stock filters with BMCs. Hopefully everything goes back on as easily as it came off. Also it was a good chance for me make sure there was no oil leak which I guess a few GT3s have seen. Everything was dry. Full disclosure I am mechanically challenged.
Akrapovic has great instructions on how to remove the rear bumper cover.
QUOTE=GrantG;15820319]Here:
https://d1sfhav1wboke3.cloudfront.ne...10597db713.pdf[/QUOTE]
Thanks!!!! Ref this document’s page 17/18, on the 16 GT3 RS there’s a fourth screw in the fenderwell compared to the GT3’s three screws. This fourth screw can be found under a hidden plastic flap along the fenderwell’s top leading edge.
Cheers
JB
Cheers
JB
