991 GT3, GT3RS, GT2RS and 911R 2012-2019
Innovative Centerlock tool...
Old 02-15-2019, 11:16 AM
BillNye
BillNye's Avatar
Originally Posted by montoya
Looks like the nut is modified to allow the wrench to torque it down- hard to tell from the video if the main CL body is retained or if that's modified as well. Any modifications cannot impact the safety of the CL nut system, which goes without saying.
Looks to me like a standard Porsche nut is turned down to accommodate the toothed outer ring that counters the torque from the motor. This is why the tool doesn't rotate while the nut is tightened.
Hytorc appears to be well versed in the torque instrument business so it's probably more thought out than is appreciated. Not sure how I feel about this solution, but kudos to them for trying something new.
I can't help but wonder why they didn't just make a custom reaction arm like is used at the factory to avoid modifying the nut.
jkfuel
jkfuel's Avatar
Pretty impressive. At that cost I'm sure it's targeting Pcar specific shops.
Old 02-15-2019, 11:22 AM
GrantG
GrantG's Avatar
Received 4,721 Likes on 2,691 Posts
In the factory method pictured above, is the nut tightened from the inner splines of the locking mechanism (and not using the special socket that came with the car)?
I assume the green piece is the reaction arm you mentioned and just rests against the inner wheel spokes? This may only work with some wheel designs...
Old 02-15-2019, 11:23 AM
Gofishracing
Gofishracing's Avatar
seeing the rest of the jig shows it's not quite as simple as hoped.
Old 02-15-2019, 11:31 AM
BillNye
BillNye's Avatar
That's correct, although it shouldn't make much difference. And I agree, it wouldn't work with all wheels, but relative to the cost/risk of modifying the nuts they could have different/custom reaction arms. Sequence starts at 45:15.
Old 02-15-2019, 11:36 AM
GrantG
GrantG's Avatar
Thanks! I'm surprised Porsche doesn't sell that tool (at least to shops for a high price)...
Old 02-15-2019, 11:37 AM
Awdnut
Awdnut's Avatar
Originally Posted by s996
That is one pretty drill motor.
My torque wrench and reducer are around $800 with a little effort.
Hytorc lion .7 as seen above is on eBay at $4500 for those that have to have all the cool toys.
New, I would guess 6-8 thousand with maintenance contract.
great find
or... Porsche could go back to five lugs
Plus if you look carefully on the video, they also replaced the Porsche centerlock nut in order to mate with the hytorc gun, hence add the cost of the 4 specialty centelock nuts to the cost
Old 02-15-2019, 03:09 PM
DaveGordon
DaveGordon's Avatar
The factory has a similar wrench, but it just pushes against the wheel spokes - seems like a better solution to me.
EDIT: sorry missed the above
Old 02-15-2019, 05:45 PM
mykalz71
mykalz71's Avatar
Default Innovative Centerlock
[QUOTE=sgroer;15640452]
Facebook Post
Probably pricey but man what a difference maker![/QUOTE
coming soon to Obsessed Garage.
Old 02-15-2019, 06:34 PM
mdrums
mdrums's Avatar
Originally Posted by tasman
Or Porsche could go back to 5 lugs
would be greatly preferred!
Old 02-15-2019, 07:24 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Seems like everything I’m about to use the big bar, there is a shop around to do it for me.
Old 02-16-2019, 02:55 AM
FLACHT6_pilot
FLACHT6_pilot's Avatar
Would love to have the option of buying a factory style solution with a reaction arm from some outlet.....beautifully engineered
Old 02-16-2019, 07:33 AM
Waxer
Waxer's Avatar
Originally Posted by sgroer
I've heard $3k for the gun, but who knows... at $3k it's tough to justify for something I do 4-5 times / yr... at $8k my wife leaves me, so I need to consider the cost / benefit
For some it’s benefit/benefit.
Old 02-16-2019, 02:56 PM
Robert Linton
Robert Linton's Avatar
Looks like an excellent company with very good engineering. Apparently the gun will need special nuts that look identical to OE on the outside. For those with more than one centerlock car, that cost will add up but should be worth it. I look forward to seeing the product.
Old 02-16-2019, 06:34 PM
mwar99
mwar99's Avatar
The center of the centerlock they used is OEM. They adapted the friction ring that gets the messy paste and obviously the outside of the ring was modified. It's really trick and was effortless.
It was obvious to me they know what they are doing. Still early in the process so who knows where it will go.
Quick Reply: Innovative Centerlock tool...
