991 GT3, GT3RS, GT2RS and 911R 2012-2019
Any known issues with 991.2 GT3 so far?
Old 02-18-2019, 12:26 PM
  #61
Argon_
Argon_'s Avatar
Originally Posted by konaforever
Too many people flipping or barely putting any miles on before moving on!
Julian Majzoub agrees.
Old 02-18-2019, 04:53 PM
  #62
fbroen
fbroen's Avatar
I drove 8,000 miles in January. No issues to report from that trip.
I have the above-mentioned clonking since day 1, piking up the car at the Factory. I "feel" it to be a deck-lid (hinge?) noise.
I did try a lot of varying surfaces and temperatures and elevations during my January trip: https://rennlist.com/forums/991-gt3-...some-pics.html
Old 02-18-2019, 07:35 PM
  #63
n2cars
n2cars's Avatar
Originally Posted by n2cars
Today the PSE stopped working. Took it into service but they couldn't find the problem. No loose hoses etc. Taking it back next week.
Porsche said my PSE was running 100% of the time. They traced the problem to the passenger side muffler. It's defective. They are replacing just the passenger side muffler. I've never heard of a problem like that? Does that sound correct?
Old 02-18-2019, 11:06 PM
  #64
1809
1809's Avatar
Originally Posted by nszombie
no issues after 3k miles aside from the big hole in my wallet
That's for sure! At least the smiles on our faces are bigger than the financial abyss we just created!
Old 02-19-2019, 08:09 AM
  #65
Porsch
Porsch's Avatar
https://youtu.be/s0JlQeCeExs?t=15
no roll bar, nothing but pure bad assness!
Old 02-19-2019, 08:10 AM
  #66
Porsch
Porsch's Avatar
somehow i'm collecting those holes faster than i'm collecting my cars!
Old 02-19-2019, 01:06 PM
  #67
johnsopa
johnsopa's Avatar
Sounds odd to me. If one side is broken the other muffler would still open and close unless there was a vacuum leak in the broken muffler.
Old 02-19-2019, 01:15 PM
  #68
Bullitt44
Bullitt44's Avatar
Only issue is my local weather. Problem should be solved soon.
Old 03-10-2019, 10:07 PM
  #69
mrhamamg
mrhamamg's Avatar
My left valve broke at ~1k miles and now the right stopped working today at 4k, taking it in this week but likely same issue as you. Hope this isn’t widespread and stops happening. Not trying to replace oem mufflers every year when warranty runs out lmao
Old 03-11-2019, 12:34 AM
  #70
Alan C.
Alan C.'s Avatar
Originally Posted by Agent_Orange
The BOSE stereo needed an increase in BASS, I found setting 8 to be adequate
Just the opposite for me . I've turned the bass way down. At '0' the system sounds like a 17 year old's '87' Honda Civic with the biggest woofer Walmart sells stuffed in the back.
Old 03-11-2019, 07:02 AM
  #71
Bobby 911
Bobby 911's Avatar
never heard of that. Did you finally get your car back?
Old 03-11-2019, 08:10 AM
  #72
nszombie
nszombie's Avatar
https://rennlist.com/forums/991-gt3-...shows-1-a.html
Old 03-11-2019, 10:01 AM
  #73
Wild Weasel
Wild Weasel's Avatar
Only two issues I've had with mine were both minor.
I had the exhaust actuator tube come off on the left side, as mentioned by others here. Fixed it myself the first time with a zip tie but it didn't hold up. Dealer put a new clamp on for me.
I had an issue with the shifter making a bit of a squeak and some rattling noises. I was sure there must be something wrong with the shifter itself but my dealer says I just need a new shift ****. This was during my year-end service before putting the car away for the winter so I'll get the new one on in the spring and see if it resolves the issue.
Old 03-11-2019, 10:39 AM
  #74
A/S
A/S's Avatar
- Launch control doesn’t work with nannies off.
It needs either TC-On or ESC/TC-On, so any competitive event where you launch from a standing start is compromised.
- The .2 GT3 RS front spoiler lip is not as flexible as the .1 version, so it cracks easily.
Old 03-11-2019, 11:25 AM
  #75
n2cars
n2cars's Avatar
Yes. Passenger side muffler valve defective. Replaced with new passenger side muffler. There were only two mufflers in stock in the country.
Quick Reply: Any known issues with 991.2 GT3 so far?
