991 GT3, GT3RS, GT2RS and 911R 2012-2019
Any known issues with 991.2 GT3 so far?
Old 02-12-2019, 12:16 PM
  #46
Fdvigna
Fdvigna's Avatar
Ha! Now I know it’s an actual defined term ... here I go again down the Porsche rabbit hole... fascinating. Thanks! 👍
Old 02-12-2019, 12:53 PM
  #47
GrantG
GrantG's Avatar
Received 4,708 Likes on 2,685 Posts
Isn't at least some of that from the rear LSD cogging when sharply turning?
Old 02-12-2019, 01:07 PM
  #48
mrhamamg
mrhamamg's Avatar
3.5k miles in 15 mos for me and only issue was the exhaust valve tubing on left side coming undone. Happened twice, third time dealer added a second clamp and it hasn’t happened since
Old 02-12-2019, 02:07 PM
  #49
gt3ish
gt3ish's Avatar
Originally Posted by Palting
About 6,500 miles so far on my 991.2 GT3, around 3.500 of those are track miles. Only issue I had was rear wheel steering sensitivity to diagonal tie downs on the tires, https://rennlist.com/forums/991-gt3-...-trailers.html , corrected itself just by driving it then going in a circle. Have tie downs to the jack points now. Otherwise bulletproof.
Likewise had failure notice issues w/ mine a couple times after trailering... . Scares / pisses snot out of you when you've just arrived at a track after a 5+ hour drive and happens on start up of unload.
Always use RennLine tie downs but finally able to trace causation... Parking brake engaged (accidentally / automatically in my case). If you tow w/ P-brake on be prepared for a full litany of failure messages (and sailor verbiage from you - LOL) upon arrival. It does go away w/ a quick drive though once it senses all is fine again.
5000 miles (~ 3k track) and all good otherwise.
Next up... remembering to keep all doors closed when lowering FAL, or attempting to remember as case has been. Not sure I'll ever get that engrained though - HA!
Good luck
File Type: mov
Old 02-13-2019, 07:56 AM
  #50
Mussl Kar
Mussl Kar's Avatar
Lichtgrun has some sort of funny noise when clutch is depressed at very low speeds in the driveway. Like a lever bouncing on something. Prob happens at all speeds but car is quiet enough to hear it only in parking maneuvers.
Old 02-13-2019, 10:36 PM
  #51
shaytun
shaytun's Avatar
Originally Posted by Sunny_M3
I've noticed (and there have been some reports) on a rear suspension metallic clunk when the suspension is jolted/unloaded (over any harsh bump or pothole); this may or may not be normal, but I'm getting my car looked at on the 20th just to make sure. There is a separate thread about the issue here: https://rennlist.com/forums/991-gt3-...-unloaded.html
Just out of curiosity, anyone else experience that noise?
I'm one of those people. I've just avoided the big bumps for now. I haven't taken my car in yet, because it seems random that people have had different solutions to the same problem. I'd be curious to see what they tell you.
Old 02-13-2019, 10:40 PM
  #52
shaytun
shaytun's Avatar
Oh yea, another thing, I definitely think it's a normal quirk, but with each shift there's a squeak at the end of the movement. Cheap sounding. Learning to ignore it. More noticeable with the the gears on the top of the H-pattern (1/3/5). Turned car off and it makes it in every gear. Shifter feels perfectly normal. Will ignore it.
Old 02-13-2019, 10:41 PM
  #53
GeoJoe
GeoJoe's Avatar
Good luck
Interesting. I'm using Rennline tie downs... no errors on the dash after towing with parking brake engaged for me. Alarm has gone off a couple times while on the trailer after the first bump or so, but nothing else. I like parking brake engaged and in neutral (6mt here) when towing.
Old 02-14-2019, 07:22 PM
  #54
kaimuki
kaimuki's Avatar
My GT3T gear indicator will sometimes show 1st gear erroneously (when I have hamfistedly put it in 3rd by accident) after backing out of my garage or parking space.
Also the Porsche Weather Modulating System is clearly broken as it continues to snow outside
Old 02-14-2019, 07:47 PM
  #55
n2cars
n2cars's Avatar
Today the PSE stopped working. Took it into service but they couldn't find the problem. No loose hoses etc. Taking it back next week.
Old 02-15-2019, 07:56 AM
  #56
nszombie
nszombie's Avatar
no issues after 3k miles aside from the big hole in my wallet
Old 02-17-2019, 12:15 PM
  #57
n2cars
n2cars's Avatar
Three days in service and they can't find the problem. They are calling Porsche tomorrow for assistance.
Old 02-17-2019, 11:24 PM
  #58
Agent_Orange
Agent_Orange's Avatar
The BOSE stereo needed an increase in BASS, I found setting 8 to be adequate
Today we drove 800+ miles and found a door rattle that occurred at the same speed each time, quite close to 3800RPM, just below break-in max rev level.
Quite soon upon every pass we would look forward to the noise and chuckle as it appeared "There it is, all must be OK!"
Even the smallest things are fun in a GT3! - LOL
Old 02-18-2019, 12:47 AM
  #59
Alan C.
Alan C.'s Avatar
I've had this issue with my 10 GT3, 15 GT3, 16 GT4 and now my 18 GT3. It has always happened when it has been cold never when warm outside. Pretty much a Winter issue for me.
Old 02-18-2019, 01:12 AM
  #60
TexasPorschelover
TexasPorschelover's Avatar
Mine crushes tires.
Quick Reply: Any known issues with 991.2 GT3 so far?
