Antigravity Batteries NEW GROUND BREAKING LITHIUM BATTERY
#61
Yesterday, I installed an Antigravity 30Ah battery in my 991.1 C2S. Today I measured the front ride height from the garage floor to the bottom of the wheel well and the passenger side is approximately 1/4" higher than the driver's side. The ride height at the back of the vehicle is the same on the right and the left. I certaining wasn't expecting that. I measured the front ride height a year ago and it was the same on both sides.
As the SPASM setup isn't adjustable, I suppose I'll have to llive with it. Hopefully it isn't noticable.
#62
The height difference probably isn’t due to battery. First it’s normal for driver side to be higher if you’re not sitting inside and alignment or grade makes a difference. Weight from stiff in the frunk will drop ride height though.
