Antigravity Batteries NEW GROUND BREAKING LITHIUM BATTERY
#47
We have a Distributor in Aus.. but they are for the Motorcycle Batteries but they also brought in a good number of the RS-30... but I'm sure they will probably bring in some of the new line....
We do ship to Aus... but the shipping is expensive, and we can't control that. Its a Class 9 Shipment and now all the Carriers ad a surcharge.
If you are driving one a week for an Hour you will NEVER have to charge the battery. First off and hour of driving will close to fully charge most any lithium battery even if its pretty heavily discharged. Then even if it was once a month or longer in a stock car without a bunch of after market accessories you can easily let it sit that long. If you don't have to put any battery on a charger, then don't. There is no need to cycle a battery unnecessarily. Just put them on a charger if you plan to not drive for a while, or if you do have a car with excessive parasitic draws on it.
Without a charging issue, a swap is must need! )
#49
Premium Sponsor
OK - good to know. TBH This is the first time the battery has let me down and the bike is close to 7 years old so not that big of a surprise the battery has failed? One other question assuming parasitic draws how long do you think I could leave the Pani sitting there without it being on a trickle charger? I'm just interested if its longer than the OEM one? As you say other bikes plus other cars make saddle time on the Panigale disappear a bit.
#50
Premium Sponsor
The Pani I assume will do about a month with the Lithium. Being honest I have one of our Older Batteries in the Panigale.... it might even be over-discharged now but I started it about 2 months ago and all was fine. I try to start it once every two months, and it is doing that but I have a older battery with about 10Ah in it.... which is more than the Pani version we sell.
#51
Premium Sponsor
In regards to a fire I would assume Lithium... just because it can go into thermal runaway when incorrectly charged, or for a few of the reasons I mentioned earlier. I can safely say is very rare, and requires a certain set of circumstances.
If you looking at broader safety... I really don't know definitely on that either... Lead can explode since it creates hydrogen when charging and if you had you hood closed and were charging and the right set of circumstances occurred you could potentially have an safety issue. It can explode also with and over-charge. Acid has leaked and destroyed many battery trays and sheet metal in older cars..othing. Lithium can potentially catch fire... but I can tell you we also have some containment measure inside our batteries... so any heat cannot readily get outside the case of the battery. The means some fire/heat proof panels on strategic areas so that any heat would not penetrate outside the case. WE have done quite a bit of testing, short-circuit attempt and more... so I'm extremely comfortable and confident in it.
#52
What's available for a starter battery today at Antigravity for a GT3 RS? Without having to wait weeks for the new 25ah-40ah stuff? I need something within 2 weeks, the amateur sport timed events are starting everywhere and my car is waiting for a battery for 2+ months already. I can't use the Porsche Lithium OEM from my 997.2 GT3, the 991 eats it in less than 6 hours.
#53
Premium Sponsor
But also are you saying your 991 eats the capacity off any battery, or just your porsche battery? The 991s are super good at having a low parasitic drain. Have you tested your parasitic draw, or do you have any accessories that are not stock that can be keeping the car awake or are eating energy? Just saying because most the 991 people can let the battery sit for a long time... and I'm talking the RS-30. Email me at scott@antigravitybatteries.com. I don't like this forums PMs... they are hard to deal with for me, and I always get my emails.
#54
I have a 40Ah in H6.... we only have a few left left now.. They are 16lbs.
email sent...
#55
Are the batteries shipped in sleep mode and need to be turned on? If not is there a specified period of time from the time the battery arrives that it can last before being installed or needing to be on an improved maintainer?
Will the 24Ah be sufficient for a 987 Boxster Spyder?
Thanks!
Thanks!
#56
Premium Sponsor
Thanks!
Thanks!
Well the 24Ah is fine for Spyder ...BUT it is limited in Amp Hours and 24 Ah will NOT sit in storage in a Car as long as a 30Ah or 40Ah Battery... So while I believe you could get a month or perhaps a little more out of it in a car that is not being driven (and without any after market accessories that could cause a Parasitic Drain) the fact it with that battery if you not driving every few weeks you would want to look at putting in on a charger if you not driving very often. I'm not at all worried about starting power. I'm worried about those who don't dive for a month at a time and let the car sit. But if you maintain you car and check it out every so often then you are fine with it. Also in very cold weather like Canada I wouldn't recommend it as much unless you only drive during the warmer times.
Last it will sit for a long time, perhaps 8 month without over discharging of going lower in voltage provided it is NOT connected to anything. IF it in the car, you have to test for that in your vehicle. For example if you get the battery and it sitting at 13.2v... then you don't drive for a week, check the voltage if it hasn't ddropeed your looking good, if you go out to 3 week and it drops a TENTH of a volt you are looking really good. So I don't have an difinative answer because I don't know the parasitic draw of ever car and they are all a little different... I can tell you the 991s and some boxster guys got about 5 weeks out of the ATX30 model we sell.... and that is only 18Ah compared to 24Ah that we offer in the new ones.
#58
#59
Premium Sponsor
Yes, the H7 option will also be available in a 40Ah option and that will be the largest capacity size.
