991 GT3, GT3RS, GT2RS and 911R 2012-2019
Garage lighting suggestions?
Old 02-05-2019, 01:32 PM
vodavoda
vodavoda's Avatar
Originally Posted by goin2drt
Wait until March/April. Big *** Fans is coming out with an amazing new single bar led fixture. Shameless plug as I work there but I promise it is what every sweet garage will need and want.
Tell us more about it....
Old 02-05-2019, 01:58 PM
bbs993tt
bbs993tt's Avatar
More info please.
Old 02-05-2019, 07:07 PM
goin2drt
goin2drt's Avatar
Originally Posted by bbs993tt
More info please.
stand by. I will get you all a doc that I can share that is for external use. They are badass.
Old 02-05-2019, 10:00 PM
PierreTT
PierreTT's Avatar
I installed Big *** Lights a few years ago
Like it and would buy again
Old 02-05-2019, 10:47 PM
goin2drt
goin2drt's Avatar
https://www.bigassfans.com/lights/led-bay-light/
Link to the light. Garage version is basically the same. I will get a pdf doc soon.
Old 02-06-2019, 11:52 AM
aaa335
aaa335's Avatar
Hi, I also went with obsessedgarage recommended lights and bulbs. I had four bays installed but had them wired on two separate switches. First pic is natural light thru garage windows. Second pic is two light bays on, last pic is all four bays on. I’m happy with the setup. Gives me flexibility to not have full bright all the time but can blast when I want to for pics/detailing.
Old 02-06-2019, 05:37 PM
ljahearn
ljahearn's Avatar
I put these in - you cannot beat the price - they are friggin awesome. Technically "high bay" but will work in a standard garage.
https://www.homedepot.com/p/Commerci...2161/302456569
Walk in/walk out at Home Depot too.....
Old 02-06-2019, 06:37 PM
joejenie
joejenie's Avatar
I'm wiring my new 22x38 garage next week. I want these single tube lights! How many would you recommend for a 22x38 garage with 12' tall ceilings. I assume normal 110 power? In a box or just hang the wire out and hard wire later?
Old 02-06-2019, 10:34 PM
goin2drt
goin2drt's Avatar
Depends how bright you want it but honestly we have an engineered app if you send me your plans and output can be calculated. Probably 6-8. 13k lumens per and yes 110. Plug can come out the top and just plugged in or can come out the side or can be flush mounted direct wired. Pendant mount, flush mount, or hanging down via aircraft wire are all options. Also will have an option for occupancy sensor. 7 yr full warranty on every part not just the structure but the led and driver. They not only look amazing but it is a tank of a light. One of the highest efficacy ratings in led and won’t deteriorate over time. Still finalizing pricing on the garage version but will be in the $300-$400 range. It is nothing like a HD $99 light. You are comparing apples to oranges in led output, efficacy and performance.
Old 02-07-2019, 03:31 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,480 Likes on 2,269 Posts
^ I was going to get these, but the single tube are better ya?
Old 02-07-2019, 08:36 AM
goin2drt
goin2drt's Avatar
Those aren’t bad, don’t get me wrong. The new light is better though without a doubt.
Old 02-07-2019, 09:13 AM
Mussl Kar
Mussl Kar's Avatar
I used a lot of recessed cans and put 75 watt eq LED down-lights in them. Not a single hot spot or cold spot. A lot of labor that I did myself and I like the clean look. Having a 7' x 16' mobile work platform at perfect height made the job easy.
Old 02-07-2019, 10:09 AM
joejenie
joejenie's Avatar
I would like to do recessed can lights, but they are against building codes unless you have a firebox on top of them which usually makes them run hot and overheat. On top of that, you end up in each light $175-200 per recessed can which gets really expensive compared to the fluorescent lights available.
Old 02-07-2019, 11:39 AM
KM1959
KM1959's Avatar
You can get them with approved "IC" or insulated ceiling ratings that don't require a firebox. This risk is further reduced by using LED bulbs which do not get anywhere nearly as hot as they use about 25% of the power of halogen or incandescent bulbs.
Old 02-07-2019, 11:49 AM
neurotic
neurotic's Avatar
thank you! how many would you need for a garage that is about 25x25 and 12-13 ft high ceilings?
Quick Reply: Garage lighting suggestions?
