JCR silenced racepipe
Basic Sponsor
We offer a Race Pipe with no silencing. This ‘silenced’ version features silencers which cut the overalls dB levels from our ‘non silenced’ Race Pipe by an average of 8/9dB throughout the RPM range
In regards to cracking I think it’s once again important to state and reassure that we have had NO such issues with any of our exhausts and I do not anticipate we ever will. I’m unsure as to why this concern keeps being raised?
Silencers aren’t really tiny, they’re sized accordingly. The internals flow accordingly and there is no temperature spike in the silencer.
As you can see from the image below with the car on the hub dyno the silencers do not get anywhere near as hot as the main exhaust, as you would expect.
JC
thanks
The install is completed, but due to the weather where I am I have only started it up and revved it a bit in the shop. So far it sounds more race like than any exhaust I've personally heard and will give a more complete review once I have driven it a bit. From my calculations, it saves approximately 38 lbs off the rear on a 991.2 RS when retaining the stock tips and leaving the rear exhaust bracket in place.
The scale I used was only accurate to 0.5 lbs and I got 22.5 lbs for each side exhausts and 10.5 lbs for the rear exhaust with tips. I forgot to remove the exhaust tips before weighing the rear muffler so assuming the exhaust tips weigh 2 lbs, the total weight without tips is approx. 53.5 lbs. I didn't weigh the JCR system as Jonny documented that pretty accurately in an earlier post at 15.0 lbs. I am assuming the added mounting hardware is about 0.5 lbs. So roughly: 53.5 lbs - 15.5 lbs = 38 lbs.
Basic Sponsor
JC
A 10dB reduction in sound level corresponds to a sound that is subjectively half as loud. So, whether coming down from 120dB to 110dB or from 70dB to 60dB, in both cases a person would experience the perceived loudness being cut in half...
Basic Sponsor
As an audio geek, I thought I would chime in with a fact that some may not have come across before:
JC
JC, I can’t speak for others but I surmise the trepidation with cracking is not directed towards your products specifically but titanium itself. I personally have had cracking issues with other titanium exhausts; did not stop me from running your titanium race pipe though.
Basic Sponsor
With our Race Manifolds we choose to use Inconel as Titanium would not be suitable but we're able to select a grade of Inconel which is capable of handling the heat whilst keeping the weight down to an equivalent of a Titanium version.
Its all about using the right materials in the correct places
Coming in Part2 of our dyno test. Hope to share that new post next week in between another 4 new product releases
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
I finally had a chance to drive the car with the exhaust. So far I have put in about 50 miles. I had the owner of the shop where the install was performed both as a passenger and driver for another assessment as he has driven cars with far more variety and exhausts as I have to compare.
Performance: I can't tell any difference, either loss or gain. I will defer to any dyno on this.
Drone: Minimal. I'd say there are some instances at 2-3K, but less than I anticipated. Once, you are past 3K, it is virtually if not completely eliminated. I realize the perception of drone is subjective, although I think I'm pretty sensitive to this.
Volume: Again, I know this is subjective. It is definitely loud, but not unbearable by any means. For comparison to a BBi rear exhaust I had on my 2016 RS, this exhaust is a few steps up. I've heard the JCR exhaust from both the inside and outside and compared to an AWE switchpath (loudest exhaust I've ever heard) the JCR is definitely a bit quieter. I was able to have a normal conversation in the car as long as it was below 4K rpm. JC says it may get a bit quieter with some carbon build up in the silencers. Personally, I am happy have the silenced version over the non silenced version,
Sound quality: I think this is the best quality of this exhaust. It sounds like no other I've heard before. I think it is a bit higher pitched and the most "race sounding" of the ones I've heard which includes many of the rear bypasses and the Akrapovic race system. I asked the installer what he thought. Prior to hearing the JCR, he said Akrapovic but I think he has now changed his mind.
Thanks Jon for the initial review.
JC created a volume scale for the different systems. He said OEM system valves open a 3. Silenced race pipe 7. Do you agree?
So cruising on the freeway at legal speeds, drone should be minimal or non-existent?
Jimmy not sure the brand but they are paper. I have some BMC's that should be here tomorrow.
