Scraping undercarriage of GT3
don't care about scraping the lip, but are there other parts of the car that gets damaged next to the lip when scraping? Not sure if thats of the front bumper extends under the lip? Referring to the new touring.
The rear underbody fins of the rear lower diffuser.... same as in the 911R.
The 991.2 GT3 (winged) and GT3 Touring has these same ones standard.... and yes they will scrape, eventually.
As Bossing said, it really is only the rear diffuser fins that can more easily scrape during normal driving. It is pretty darn low if you look. When going over speed bumps, take caution on the downward "slope" as the car may dip hard and hit the fins. Sounds scary the first time.
If you're used to driving lower cars, the front lip isn't so bad. If you have the lift, it is even better. The rear is what you have to watch out for. The lift actually lowers the rear fins by a tiny amount too.
The front lip replacement (dealer cost) is only about $230ish so it isn't bad considering it is an OEM Porsche part.
Don't go full speed up/down a driveway and you'll be good.
There are no "fins" in the front if that's what you're asking. The front end is lower than your average car, but I wouldn't say it is ridiculously low (your average young kid in a slammed Honda is probably lower :P ). You do have to be careful, take sharper inclines at an angle, etc.
It's not just the front lip. There are ducts that are in front of the front wheels that are actually lower than the front lip. Those get destroyed if you drive the car. They are attached to the front tray under the frunk area. At some point they will need to be replaced, but I figured why bother if they are going to be destroyed again. I know they scrap on the road and I have had them scrape on track with certain dips/turns.
Pretty sure I've scraped all 3. Front lip, the fins/ducts in front of the front wheels, and the rear diffuser in the back lol
First cut always the deepest
Cause, as MWAR99 stated above... if you DRIVE the car... they WILL get hammered!
