GT3, PSE, and winter.
Alright, I couldn't stand it anymore, so I took the trickle charger off and took the car out today for a long drive. No snow, salt got washed off by rain last few days, freezing cold but I'm replacing the tires in the spring anyway, so off we went. Had the smile on my face frozen even though the AC was set at 72.
Is it just my addled depraved mind, or does the cold air seem to make that 4.0 NA motor more torquey? I know it would for turbos, but I didn't think it would for NA engines. And the exhaust!! Cold air seems to make it more boomy, more baritone. More satisfying!
if I remember ideal gas law right, then if all else constant, if t drops then moles have to increase. so higher O2 per stroke and I assume ECU dumps in more fuel to keep the A/F ratio gods happy. So, yes? Also denser air so greater conduction, therefore louder. I'm less certain why this is but I think it ends up being the right answer. Maybe because less dispersion of the pressure pulse in denser air? Please correct me if I'm way off-base here.
Perfect formula. More power and sound and riding on tiresicles with all the traction of a billiard ball. Steer with throttle time and hope they keep the salt and sand away for a bit longer.
SJW, a Carin' kinda guy
All seasons are doing great for me. Heading out to get some more miles to get through the break in period. BTW anyone who can keep it under 4K is much better than me as I know I hit 4200 a couple times.
