991 GT3, GT3RS, GT2RS and 911R 2012-2019
Gt3 always comes on with ac fan on... compressor probably too
Old 12-11-2018, 03:53 AM
jjrho
jjrho's Avatar
Default Gt3 always comes on with ac fan on... compressor probably too
Is there a way to get the engine started without having the ac fan ON at the start of the car ?
gt3 has no key fob memory function. Etc.
just annoying to have fan or compressor ON at starting....
I read other threads but no satisfactory answer ...
Old 12-11-2018, 07:48 AM
cox1974
cox1974's Avatar
Same here .. Ac always on
Old 12-11-2018, 08:11 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
No. Fan always on at start up.
Old 12-11-2018, 11:47 AM
ilovecarbs
ilovecarbs's Avatar
Nope, hate it. Also hate how you can't have it in recirc. without the air on.
Old 12-11-2018, 11:57 AM
MovingChicane
MovingChicane's Avatar
Same experience here.
Radio is another thing; sometimes it's on and sometimes it isn't.... Actually it's always on it would seen, just the volume is "on" or ins't.... ?
Old 12-11-2018, 12:40 PM
GT3PDL
GT3PDL's Avatar
They are all programmed at the factory to default to "on" at start-up. It does not bother me, but I've had two buddies take their car to the dealer to be reprogrammed to default "off". Pretty simple parameter change any Porsche dealer can change for you.
Old 12-11-2018, 02:52 PM
GT3 KSA
GT3 KSA's Avatar
I would turn the key to the right one click without turning engine on and would turn ac off before half a second even passes then i turn on engine so when engine is on ac and fans are off in this scenario
Old 12-11-2018, 04:52 PM
mwar99
mwar99's Avatar
Just curious as to why someone would be concerned with this?
Old 12-11-2018, 05:58 PM
The Pope
Holy Guru
Registered Pontiff
The Pope's Avatar
Same question I asked myself. Just hit the the A/C button when you start the car and it's off.
Old 12-11-2018, 06:08 PM
major dad
major dad's Avatar
Because it’s a pain to do so. Mostly I don’t need AC on and t makes my MPG worse so I’d prefer it off as default.
Old 12-11-2018, 06:19 PM
SmokinGTS
SmokinGTS's Avatar
I just checked my 15 GT3 and found that if the AC switch was in the on position at shutdown it was one on the next restart. The opposite is true, if it was off at shutdown it is off on the next restart.
Old 12-11-2018, 06:24 PM
The Pope
Holy Guru
Registered Pontiff
The Pope's Avatar
That's the way it should be but the '18 manual states that if A/C is in auto mode, it will always default to on when car is started. Someone try taking it off the auto mode and see what happens.
Old 12-11-2018, 11:17 PM
JC68
JC68's Avatar
My 18 GT3 is like this. And it is not in auto mode.
Old 12-12-2018, 12:30 AM
mwar99
mwar99's Avatar
Your worried about gas mileage in car that's going to average less than 20 mpg? The hit from the air compressor is not killing your mileage. I've seen many a car with fogged up windows driving down the road - wish their AC turned on automatically, would make me feel safer driving on the road with them...
Old 12-14-2018, 07:40 PM
major dad
major dad's Avatar
Poor gas mileage equates to loss of power somewhere, I’d prefer to have the extra BHP to use as I wish. You’re right about some drivers driving with fogged up windows, though not me. Fogged up windows are often caused by having the fan at 0 speed, nothing to do with Air Con in their case but can be caused by not using the air con too.
Quick Reply: Gt3 always comes on with ac fan on... compressor probably too
