Gt3 always comes on with ac fan on... compressor probably too
With both my 17 Turbo S and 18 GT3 that I had you can turn off the auto A/C start default using the door set buttons........I turned key to the ignition spot, turned off AC via the button, then set the fan to zero or off, hit the set button first and then the key set button........................was successful in turning the A/C off..............
Now the regular fan comes on at 70 degrees on one click of the fan................I will solve that when I have some time, probably doing something with the temperature setting for it to start with being in the total OFF default...........
Try what I had success with the AC and let us know..........thanks......
