GT3RS SOUL Centre Muffler By Pass (CMB) Install - Page 4 - Rennlist - Porsche Discussion Forums
991 GT3 GT3RS and 911R
Old 01-14-2019, 05:48 PM
  #46
Soul Performance
Basic Sponsor
Soul Performance's Avatar
Originally Posted by Richard. View Post
I am still a bit confused, center muffler delete sounds better and is muuuuch cheaper (if you include labor) so why would you do side mufflers ?????????????, I can understand if you do them both but side mufflers should be nobody's first choice
Originally Posted by 1809 View Post
I'm sure John can answer this better than I can, but my understanding from the reading I've been doing is there seems to be some additional weight savings and less temperature rise in the rear tires (both things more important for people tracking the car) with the SMB. It seems some people might also like the "milder" sound upgrade of the CMB when compared to the SMB.
That is very well said Chris
Richard, here is an excerpt from the initial post of my "Side Muffler Bypass Vs Center Muffler Bypass Explained", hopefully this should give you some insight on why a fair amount of people choose to go with side muffler bypass pipes
"Side Muffler Bypass Pipes (SMB) are smoother and more exotic in pitch, akin to the factory exhaust note but uncorked and much livelier with a better tone. It is not quite as loud as a center muffler with valves open, and with valves closed it is not quite as quiet. However, it still has minimal drone characteristics due to routing the exhaust through the more restrictive top entry of the factory center muffler with valves closed. SMB’s also have a much smoother and less notable transition from valves closed to open vs a CMB. Also for reference, our non-valved SMB’s offer essentially the exact same sound as our valved SMB’s in the valves open position. Eliminating the valves saves an additional 3lbs which is ideal for more dedicated track cars that don’t need PSE functionality.
We utilize a dual inlet design for our side muffler bypass pipes that utilizes both the upper and lower entry to the center muffler. This bleeds off pressure into the top of the center muffler, more evenly distributing the pressure and promoting the life of the factory center muffler. We also utilize a flex pipe in the upper pipe to prevent fatigue and to allow for easier installation. I have yet to experience a factory center muffler fail when used with a dual entry side muffler bypass and factory headers, including dozens of GT3’s with thousands of track miles at Sebring during my time building GT cars in Florida.
Side muffler bypass pipes are an underrated modification, especially for track enthusiasts. Side muffler bypass pipes have two distinct advantages over a center muffler bypass from a performance perspective – weight and heat. A center muffler bypass saves around 10lbs of weight off the rear of the car while dual entry side muffler bypass pipes save about 35-38lbs depending on whether or not they contain valves. Side muffler bypass pipes also rid the car of a notable amount of heat soak just inches off the rear tires. This helps with more consistent / cooler tire temps at the track, especially if idling or warming up the car in the pits / paddock prior to going out for a session."
Soul Performance Products
Outstanding Exhaust Solutions, Fair Pricing, and Quality Service
John Gaydos - Performance Specialist
PCA National Instructor
Cell - (484) 883-6197
[email protected]
Mike Spock - Marketing Manager
Office (855) 486-1400
Soul Performance is offline
Old 01-19-2019, 06:57 PM
  #47
Mr.Wingtip
User
I have one to install. Any advise or instructions?
Thank you
Mr.Wingtip is offline
Old 01-20-2019, 06:20 AM
  #48
goldberg
User
The only advice i could offer is losening the bolts / screws for the side mufflers, to allow you more wiggle room and it also helps with positioning.
Its a really easy straight forward install.
I did mine on the ground but had the rear of my car on a little ledge to help with access.
goldberg is offline
Old 01-20-2019, 06:22 AM
  #49
goldberg
User
Is there much drone at cruising speeds with the CMB?
No drone at motorway speed (115/120 KPH)
If your on it, there is "sound" but i wouldnt call it "drone"
Its a really nice sound. Not intrusive at all.
goldberg is offline
Old 01-20-2019, 06:24 AM
  #50
goldberg
User
Originally Posted by Soul Performance View Post
Thanks for the awesome videos guys! If you have social media tags via instagram, please let me know I'd love to feature you
I have instagram, but i dont post on there.
Although you are welcome to post on your social for advertising etc. Thats fine. Just dont tag me please.
goldberg is offline
Old 01-20-2019, 06:30 AM
  #51
goldberg
User
https://www.dropbox.com/s/u1pa656d9v...Movie.mp4?dl=0
Cold start with CMB.
You can hear the transition from valve closed to open at 15 seconds.
Sorry for the shaking. That was my iPhone (X) just resting. I guess it was the sound waves shaking the lens? Weird.
goldberg is offline
Old 01-20-2019, 02:11 PM
  #52
Mr.Wingtip
User
Thank you Goldberg! It helped me get it done.
Old 01-21-2019, 01:22 AM
  #53
goldberg
User
Youre welcome.
See quite an easy and straight forward task.
I feel even doing the side mufflers would be just as easy with the addition of taking the rear bumper off. Which in itself is easy to do. I personally have not done it, but i think it would be much similar to the CMB.
Post some pics / vids!
goldberg is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
