991 GT3, GT3RS, GT2RS and 911R 2012-2019
Close to getting "Bitten" by the GT3...anyone else?
Old 12-11-2018, 02:59 AM
silvertige
silvertige's Avatar
It's already happened to me a couple of times in rainy conditions. But like others have said, its probably cold tires/ pressures.
Old 12-11-2018, 03:22 AM
Fdvigna
Fdvigna's Avatar
Originally Posted by jackmac
At least a few times that I could recall. Had my .2 GT3 manual for a few weeks now, still in the break-in period.
I have noticed a few times under moderate acceleration (despite dry pavement/tires warmed/pressures checked), the rear tends to slip/snap loose.
Caught me by surprise a few times, a bit scary feeling. I guess this car deserves some extra attention and respect. Not sure if owners experienced similar events?
Thanks,
Jack
Notice the same thing... it is a combination of throttle v cold tires and the quality of the tarmac. It is part of the learning curve of these cars (at least mine)... they are powerful machines and can not be under-estimated. I am following the advice of some of our forum members and I'll be taking some track lessons to learn more about the car, its capabilities, response and limitations. I love it!
Old 12-11-2018, 11:13 AM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
Leave nannies on.
Old 12-11-2018, 11:36 AM
RobbieRob
RobbieRob's Avatar
Originally Posted by evilfij
Leave nannies on.
This^, nannies are your friend.
Old 12-11-2018, 01:41 PM
C5driver
C5driver's Avatar
"Tru dat, homie" - Mustang owners
Old 12-11-2018, 02:14 PM
Mussl Kar
Mussl Kar's Avatar
Mine does it often. Makes me smile.
Old 12-11-2018, 03:30 PM
sheerk
sheerk's Avatar
What was the temp outside? GT3.2 does have a lot of power and torque (despite what most people say) but it’s also one of the best RWD cars to put the power to the ground...prob a combo of cold temps cold tires and uneven road etc
Old 12-11-2018, 03:43 PM
jackmac
jackmac's Avatar
Outside temp was around 48 F. I did drive at least 15-30 min so I assume tires have been warmed. Could not imagine turning traction control off...
Jack
Old 12-11-2018, 04:47 PM
GrantG
GrantG's Avatar
Received 4,708 Likes on 2,685 Posts
Jack
This is your issue. I assumed the temperature was warmer than this, since you're in CA. The Cup tires don't work well under 55F. You cannot put enough heat into them on the street in that weather. At a track, you might be able to get them to proper temp after a few laps, but not at any sane street pace.
If it's really sunny, you might have high enough surface temp at 48F ambient - but in most cases you need >55F...
Old 12-11-2018, 04:56 PM
jackmac
jackmac's Avatar
Interesting fact, appreciate the input.
Jack
Old 12-11-2018, 05:07 PM
GrantG
GrantG's Avatar
Jack
Sure - sorry that it may not be the answer you wanted. GT3's come on what are basically racing tires (even more extreme than what are generally known as Summer tires). For use in cool/cold temps on the street, the Cup tires basically behave like you're driving in the wet (or other reduced friction situations). For those of us who are used to driving old 911's in low friction conditions, it's no big deal (but still requires full attention and reduced pace). For someone who may not be expecting greatly reduced grip, it can be quite eye-opening (or even dangerous). Unfortunately, Porsche has not made it easy for someone to fit Winter or even All-Season tires for use in colder conditions. To do it properly, it really requires a second set of wheels (11" rear width, optimally).
Your grip may improve noticeably, once you're worn away the mold release that was mentioned earlier in the thread. But they are never going to behave at 48F like they do in the warm weather.
Quick Reply: Close to getting "Bitten" by the GT3...anyone else?
