It’s going to be in the 30s...Dunlop Sport Max tires
#31
Originally Posted by cobrien
I've got Pirelli winters on my stock GT3 wheels, no issues . 911s are great in the snow with the right tires
#34
My Porsche dealer mounted the Pirelli 295s Sottozeros for me with no issues at all..tires fit on the stock rims fine. So if all else fails maybe try your local dealer?
#36
This is what can happen on a Pirelli DH in the cold...
#37
Performance tires are designed to work in warmer temps...60 degrees and higher generally. The tread compound is designed to handle heat and to provide maximum grip at higher temperatures. When the temps drop, the rubber gets harder and less flexible and you lose grip. When it gets cold enough for long enough, the rubber can become so hard that it cracks under stress, which ruins the tire. Obviously as you use the tire it warms up, but cold pavement and cold air can suck the heat out of the rubber faster than you can put it in, especially if you're just driving on the street. Winter tires are just the opposite...the rubber compound is designed to stay soft and flexible in cold conditions, so they maintain grip. But, as temperatures get higher, the rubber is too soft and can't handle the heat and deteriorates quickly. All-season tires are somewhere in between...ok in the heat, ok in the cold, not great in either.
Supposedly can crack the rubber at -10C (or +14F) or below. This happens whether driving or just storing in a place where they are exposed to this cold.
Tirerack says not to store below 32F:
https://www.tirerack.com/tires/tiret...jsp?techid=221
Michelin info:
Michelin info:
#39
Overnight temps were in the 20s. I tracked them at Barber in the 30s. Ended up with some outstanding lap times in the 40s and kept an eye on them all day. I didn't notice any cracks until late in the afternoon Figured I had pushed my luck enough already and called it a day.
#40
My vote - order the snows from Porsche and never think twice - 0 degrees, sunny, and dry - I am all in for driving the RS. More power too.
Sorry - nose lift was up (Winter wheels/tires)
#41
The roads are salted, the car is in the garage with the trickle charger connected, but I'm giving this winter driving thing some thought since I'm getting severe withdrawal symptoms. Setting aside the idea that road salt will get all over, under and inside the car chassis for the moment.
Most of us who want to and do drive in the winter will do so on regular surface roads, roads that are plowed and salted. So long as we are smart about it, we can use our standard tires. The issue is that the cold can make these R compound tires hard as rocks permanently, and can crack or damage them.
So, why not just regular, non-R compound tires in the correct sizes, rather than snow tires that are the wrong size? Here's an all season tire in the right size: https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE980AS&frontTire=435WR 0RE980ASXL&rearTire=03WR0RE980ASXL&vehicleSearch=true&fromCompare1=yes&a utoMake=Porsche&autoYear=2018&autoModel=911%20GT3&autoModClar=Standard%2 0Brakes. Nothing beats the R compounds in the summer for performance, but these all seasons should be better in the winter, likely also a better deal than snow tires on cold but plowed and salted roads. Even the summer tires, like the Mich 4S may be better No?
#42
Michelin info:
Michelin info:
#43
It is time.
#44
So, why not just regular, non-R compound tires in the correct sizes, rather than snow tires that are the wrong size? Here's an all season tire in the right size: https://www.tirerack.com/tires/tires...ndard%20Brakes. Nothing beats the R compounds in the summer for performance, but these all seasons should be better in the winter, likely also a better deal than snow tires on cold but plowed and salted roads. Even the summer tires, like the Mich 4S may be better No?
#45
