Seat Electronics of LWB's vs Sofas
I am sure this has been covered at length but I can't seem to find the answer.
If I order a car with LWB's but am able to find a set of used 4 way or 18 way sofas, will the electronic functions of those seats work with the power supply?
Its hard to not order the car with LWB's but I really want a set of sofa's for daily use. I would even like to see if I could get an upholstery shop to replace the sofa seat inserts with houndstooth like can be done with the LWBs.
Any thoughts or recommendations would be appreciated!
Sorry, don't know the answer to your question. I think the sofas that come with RS are the 18-ways and I imagine those could have different demands than the 4-way sofas or LWB's.
Its not for the RS. I have buckets in it and the GT4 and love them on the track and on the weekends, but not everyday. I am thinking of trading the GT4 for a GT3T and at the end of the day want sofas in the GT3T.
As I understand it.
If you have LWBs stock, it's a pain to swap in sofas because you must add functionality to the wiring harness.
Much easier to go from stock sofas to LWBs as it's simply a subtraction of functionality.
That's what I figured. I think I'll stick with the basic 4 ways unless I can find a good reason for the 18 ways. Thanks!
I had my dealer swap 4ways into my touring. It was successful, but he charged me more than I thought
Originally Posted by chillindrdude
As I understand it.
I am considering the same thing (thanks, CBrett)
This is not correct. Assuming you start with LWB the only thing that isn't in the harness from the factory is the seat heating. The power, airbag, occupancy sensor, and seatbelt components of the harness are common to both cars. Since the GT cars don't get the fancy keyless entry and memory programs all of the controls other than seat heating are local to the seat and powered off the 12V in the harness. When I pulled my 18 ways out of my .1 GT3 I adjusted them with a 12V supply out of the car and used them as lounge chairs in my office...
I will report back what I find out.
Thanks for the great info re: the harness. Encouraging.
