Delete
Delete
Found the answer, thank you.
I have put a few hundred miles on my manual GT3. When I’m cruising along in 3rd or 4th, and perhaps while in other gears, my stick intermittently “jumps”. Not sure how else to describe it. The stick doesn’t jump out of gear or anything like that, they are just small jumps. But the stick doesn’t seem to be completely set or locked in to gear. Wondering if this is normal or if I need to take it in for service.
If you do a search you’ll find a long discussion.
Found it, thank you.
