Winmax WE1 - Endurance brake pads
I've reached out to the North American distributor for pricing and availability of these pads. Based on the friction profile, lower initial with mild torque increase with heat (very similar to Pagid RS29 and PFC08), these look like another type of pad which may be ideal for track use, to avoid early ABS jump in.
They aren't known well in the US much, but they are well known in the Japanese racing market, and also in Europe. Highly respected outfits like RSR Nurburg (Ron Simmons Racing) who live on the Nürburgring outfit all their cars, including their track-special 991 GT3's with the Winmax WE1 enduro pads.
Just wanted to bring some attention to these. There seems to be a growing trend of 991 GT3 owners who, like I, have also not been thrilled with these ultra-high bite, high friction pads that don't allow the precision/control desired on the brake pedal. It's been said that stock pads work great, and we all know Pagid RS29's work great too, so hopefully this will be another good option for those who want increased modulation. Interested to see how they compare cost-wise as well.
http://winmaxusa.com/products/
https://www.standardvsmodified.com/
I've since confirmed the pad numbers, and prices. I was quoted by Evasive Motorsports at $351 front, $297 rear (List price is $390 and $330). They have to import them, which will take a few weeks, but I'm going to give them a try as well.
These cost significantly less (about $200 less than Ferodo or Pagid) than any other comparable pad available, and are an endurance compound with a lower bite and Mu, similar to Pagid RS29. .
Winmax WE1
Fronts: 1401
Rears: 1402
Winmax WE1
Fronts: 1401
Rears: 1402
It's actually a pretty big difference, especially at the initial brake phase (about 20% less). The friction of the DS1.11 is a stout .48-.49 all the time, where the WE1 is .35 at around 200C, and .39 around 300C, peak of .45 well into the brake phase. This will be a night and day difference on the initial application. The ultimate stopping power will be there, but will require some heat and pedal pressure. That modulation with pedal pressure is what I feel the DS1.11 lacks.
WE1 has a pretty decent rise in friction between 300-400C, but I don't think that's anything of concern, as it begins to trail off slightly as it gets hotter, which makes it super easy to trail brake on. The RS29 numbers are virtually the exact same from 300C to 700C, which is typically where track pads operate. I've never had a problem with ABS using RS29 pads, nobody does. I know these friction plots are just like hp dynos, they vary based on the setup and system used, so same numbers can still be different, but that's all we have to base it on besides actual testing.
I actually sent an email to Ron Simmons at RSR Nurburg about the Winmax pads, because they use them on literally ever track-rental modified car they have, so they should have some input as to how they compare to Pagid or Ferodo…..hopefully they will take time to answer me.
Ah good point on the initial bite after theyve cooled between braking zones. My issue with the DS1.11 has been ABS triggering on initial brake application as well (which is one reason I prefer stock pad feel), especially in areas with a lot of weight transfer where the front wheels are less loaded and the pedal goes stiff with reduced stopping power.
As they say, proof is in the pudding, so we'll see how it goes. RSR Nurburg did reply and said they reached out to their instructors about how the WE1 performed on their GT3's, so should have some decent input soon as well.
Interesting I switched to Girodiscs from PCCBs on my GT4 and didnt really feel much if any difference. I used the Ferrodo DS2500 pads. No changes via PIWIS.
