Are there any exotics that handle better than a 991 GT car?
#31
Is it an exotic? No, it's a Porsche GT car which I totally feel is a class all by itself.
#37
I've said this before when comparing the GT3 to the TTS, but I think the same applies when comparing the GT3 to the Performante.
The GT3 makes you want to be a better driver.
The Performante makes you feel like you are a better driver.
#38
I've driven both at the track, 720s out handles 991 gt cars.....
#39
Regarding a "better" handling car; I think a car that handles the best is defined on how fast it can go around a corner. Which, from my experience in the cars, the GT3 does damn near the best. 720s is the only thing that really bests it in the handling in regards to how fast it can go around a corner (that I've driven). However, and we'll use the 458 as an example, it is easier to drive nearer the limit. Most guys could look like a better driver in the Ferrari and can more easily extract the cornering performance from a Ferrari. With the right driver, a Porsche is tough to beat. A Porsche is a tricky car and requires careful use of the brakes for a proper slip angle on entry and early throttle to plant the grip in the car through the corner and on exit. You need to have excellent car control and cant be afraid of getting a little sideways at high speeds. TBH, the problem with a GT3 is how good it handles on the street and how uneventful it can be if you don't push it hard enough. A 458 will give a lot more thrill through the canyons at 60mph when you'd need to go 80mph to have the same fun with the Porsche. Hope this makes sense.
#40
+1 as well. When I started having “less” tires for street-use in my Porsches, I found them more fun to drive as limit becomes more accessible in the streets.
#41
I did Dream Racing in Vegas. Drove the SV Aventador and the GT3 RS.
Maybe it was because I drove the GT3 first and got a better feel for the track but I ran a couple seconds faster in the Aventador SV. The Aventador slid around a few times (hard braking to avoid amateurs in front) but I felt like it had better grip.
#42
Just took my lt600 for the first time yesterday...without question, it crushes the handling of every GT car I've ever had (I've not been in a 991.2 3rs yet, which would be closer though). id maybe like 235/245 tires in front vs the 225 there but honestly it still does the job...
