Naturally-aspirated Porsche 911 GT3 to stay
#76
My 911 is well under 900kg - makes a huge difference to lose that sort of weight. It's possible that emissions and consumption constrainsts could push cars in that direction, but electric cars will never be that light without a big breakthrough in battery tech.
#79
#80
Originally Posted by Jimmy-D
I believe moving forward 8 speed PDK will be the new trans..
I also think 8 speed may make the car more engaging because one will be shifting more- who knows?
#81
Using 4 shafts instead of 2 may change the way the overall ratios are achieved, but gears 6, 7, and 8 will all be quite tall in the 992 Carrera PDK...
#82
Originally Posted by GrantG
In the current Carrera PDK, both 6th and 7th gears are already over-drive gears. With an 8spd, there will still be a minimum of 2 overdrive gears (and likely 3). GT3 could be a different story...
#83
I don’t get Panorama anymore - are you saying they’ve already published final drive ratios for the 992 GT3??
#84
#86
Here you go regarding the 55kg of weight increase
Body 12kg
Particulant filter 10kg
Gearbox 20kg
Wheels ? Guessing 4-5kg
Other ? 8kg
Total 55kg. Still wondering about the 8 speed and use in the GT3. I wonder if they might cast the casing of this heavy thing in Mag to claw back some of the weight increases
Body 12kg
Gearbox 20kg
Other ? 8kg
#87
Body 12kg
Gearbox 20kg
Other ? 8kg
Body 12kg
Gearbox 20kg
Other ? 8kg
1 there is no functional benefit 2 they already have a 7 speed geared for track use, 3 the GT3 doesn’t have to use the same PDK gearbox as Carreras (note the 6 not 7 speed manual), 4 last but not least , the GT3 is about lightness and anything that unnecessarily adds 15-20 kg can and will likely be eliminated!
#88
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
Body 12kg
Gearbox 20kg
Other ? 8kg
Body 12kg
Gearbox 20kg
Other ? 8kg
#90
i don’t think it’s a forgone conclusion that the 992 GT3 gets the 8 speed PDK, when
